Author Topic: Observe this intake...  (Read 13171 times)
Reply #30April 30, 2013, 01:51:30 pm
Re: Observe this intake...
« Reply #30 on: April 30, 2013, 01:51:30 pm »
Intake acquired, now how do I get the EGR leavings out of it..  lol
The TDI guys seem to burn it out, wonder if letting it sit in a bucket of biodiesel for a few days will soften it up enough
to spray away?
Fire is the agreed upon easiest and fastest way to get the coke out of the intake..
or you could try bio-d, and some heavy duty scrubbing..
i used the hot tank at my school to get lighter deposits out of TDI intakes..
Reply #31April 30, 2013, 05:57:51 pm
wolf_walker
  • 1205
« Reply #31 on: April 30, 2013, 05:57:51 pm »
Course I can't find bio-d when I actually need some.  One joint in town seems to want a membership or some such.
It's not crazy bad like the TDI's get, just sludgy in the EGR passage and at the curve down to the runners on the backside, right
where you'd expect stuff to gather.  I'll much with it a bit and see what I can do.
Mentat Text Two
Reply #32May 01, 2013, 05:44:18 am
Gizmoman
  • 1301
« Reply #32 on: May 01, 2013, 05:44:18 am »
Maybe carb cleaner? I haven't used it in years so they may have backed off on how strong it is but as I recall, it was pretty knarley at removing stuff from aluminum.
Reply #33May 01, 2013, 06:13:38 am
bbob203
  • 1789
« Reply #33 on: May 01, 2013, 06:13:38 am »
acetone and atf i hear disolves deposits pretty well. probably could mix up a big batch pretty cheap and let it soak for a day or two.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #34May 01, 2013, 08:22:15 am
wolf_walker
  • 1205
Re: Re: Observe this intake...
« Reply #34 on: May 01, 2013, 08:22:15 am »
They don't seem to sell chlorinated brake cleaner here, which was my first thought. The house brand autozone carb cleaner made a pretty fair dent in it though. The process continues.
Sent from my SCH-I535 using Tapatalk 2
Mentat Text Two
Reply #35May 01, 2013, 04:00:58 pm
wolf_walker
  • 1205
« Reply #35 on: May 01, 2013, 04:00:58 pm »
The longer runners on the NA intake are a bit of a challenge, as is the EGR passage itself.
A braided steel cable with one end frayed out and the other end chocked in a drill seems to
work well for cleaning it out too.  Still some crud on the post-hump side of the EGR
but it's getting better.
Mentat Text Two
Reply #36May 01, 2013, 05:55:09 pm
bbob203
  • 1789
« Reply #36 on: May 01, 2013, 05:55:09 pm »
a hardcore baby bottle brush or wine bottle brush in a drill. you can get the ones for 5gallon carboys at brew shops theyre about a meter long and flexy.
03 Jetta wagon TDi
Reply #37May 01, 2013, 06:13:23 pm
wolf_walker
  • 1205
« Reply #37 on: May 01, 2013, 06:13:23 pm »
Made one with braided steel cable, frayed one end, plastic coated cable, worked well.
Mentat Text Two
Reply #38May 01, 2013, 07:19:08 pm
  • 2931
« Reply #38 on: May 01, 2013, 07:19:08 pm »
Well, I found an intake for what I was willing to pay I think, it's an EGR model but looks easy enough to blank off.
Don't think I'm going to find anything else in the timeframe I have to work with so it's this or nothing.
Now I have to cobble an intake hose and filter.
So what kind of intake did you end up with?
 Any pictures?
Reply #39May 01, 2013, 07:42:14 pm
wolf_walker
  • 1205
« Reply #39 on: May 01, 2013, 07:42:14 pm »
http://imageshack.us/a/img268/6186/20130501193722240009323.jpg
Thought about cutting the egr tube off and welding up the hole, but screw it, block off plate it is. Few weeks from install.
And I bought a pop tester and six sets of core injectors. :-)
Mentat Text Two
Reply #40May 01, 2013, 07:47:56 pm
wolf_walker
  • 1205
« Reply #40 on: May 01, 2013, 07:47:56 pm »
For future reference, runners are 11 inches more or less from flange to plenum entry.
Mentat Text Two
