Author Topic: FS: 1992 AAZ Syncro Passat  (Read 6702 times)
April 09, 2013, 10:34:38 pm
Big Daddy Roth
  • 298
« on: April 09, 2013, 10:34:38 pm »
I built this car 3 years ago by combining a 1993 AAZ B3 with a 1992 syncro B3. A very complete and detailed swap.
The syncro body and chassis have about 300,000K. The bottom end was rebuilt approx 15,000k ago.
Engine
  • 1.9 TD
  • Giles IP
  • K14
  • G60 SMIC
  • 2.5" SS straight through exhaust
Driveline
  • Complete rebuild when I did the swap
  • EGR O2C (mk4 TDI gears)
  • new VR6 clutch with previous engine install
  • new CV's on prop shaft
  • both hanger bearings in good condition
  • new seals on rear diff
Suspension/Brakes/Steering
  • All fresh parts when I built the car (struts, pads, rotors, arms, bushings, bearings, ect)
  • ABS swap from 97 VR6 Passat
  • mk4 rear calipers
  • VR6 sway bar
  • ZF rack
  • R32 control arm bushings
  • new tires
Interior/Exterior
  • Everything electrical works as it should
  • A/C blows nice and cold
  • Glass moon roof
  • E-codes with Eurowires kit
  • Auber digital boost and EGT gauges
  • OEM keyless entry
The body is pretty good for a car with 300,000K. Nice and straight with couple of minor rust spots.
I've daily driven this car since I built it and have loved it, but I have a TDI syncro coming out of the shop soon and I cant keep both.
$5000 obo
Located in Victoria BC
Does not come with DE's, grill, and BBS wheels as shown. Comes with E-codes, stock grill and syncro wheels.
« Last Edit: April 09, 2013, 10:36:53 pm by Big Daddy Roth »
1993 TD B3 Sedan
1992 G60 Syncro B3 Sedan
Reply #1April 10, 2013, 08:01:49 am
rallydiesel
  • 1880
Re: FS: 1992 AAZ Syncro Passat
« Reply #1 on: April 10, 2013, 08:01:49 am »
Yummy. Did the crank nose get any attention or still keyed?
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2April 10, 2013, 08:16:31 am
bbob203
  • 1789
« Reply #2 on: April 10, 2013, 08:16:31 am »
It looks like he has a clutched alt pulley which I as far as I can tell removes the need for that?
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #3April 10, 2013, 10:22:04 am
Big Daddy Roth
  • 298
« Reply #3 on: April 10, 2013, 10:22:04 am »
The crank nose has been done.
Edit: The clutching alt pulley has been removed.
1993 TD B3 Sedan
Reply #4April 10, 2013, 07:02:13 pm
Syncroincity
  • 727
« Reply #4 on: April 10, 2013, 07:02:13 pm »
Sweet ride... If that were a wagon I'd seriously consider it, I was looking to get Dr. Diesel's B3 before he left. GLWS!
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
Reply #5April 11, 2013, 10:58:22 am
Big Daddy Roth
  • 298
« Reply #5 on: April 11, 2013, 10:58:22 am »
If someone wanted to buy this car for a swap, I could negotiate a deal with less extra stuff on the car. Gauges, wheels, e-codes, Giles IP, etc.
I'm selling the car as a driving vehicle, not parting-out.
1993 TD B3 Sedan
Reply #6April 11, 2013, 05:30:26 pm
bbob203
  • 1789
« Reply #6 on: April 11, 2013, 05:30:26 pm »
If you want to sell those headlights....
03 Jetta wagon TDi
Reply #7April 17, 2013, 08:06:39 am
Big Daddy Roth
  • 298
« Reply #7 on: April 17, 2013, 08:06:39 am »
new engine and trans mounts
1993 TD B3 Sedan
Reply #8May 01, 2013, 04:46:57 pm
Big Daddy Roth
  • 298
« Reply #8 on: May 01, 2013, 04:46:57 pm »
up
1993 TD B3 Sedan
Reply #9May 01, 2013, 06:53:19 pm
« Reply #9 on: May 01, 2013, 06:53:19 pm »
X2!
Reply #10May 03, 2013, 09:54:44 am
Big Daddy Roth
  • 298
« Reply #10 on: May 03, 2013, 09:54:44 am »
offers?
Any interest in a part out?
1993 TD B3 Sedan
Reply #11May 03, 2013, 11:39:24 am
bbob203
  • 1789
« Reply #11 on: May 03, 2013, 11:39:24 am »
im wondering how is it an aaz but has 120 amp alternator? how is the tach working?
03 Jetta wagon TDi
Reply #12May 03, 2013, 01:39:24 pm
Big Daddy Roth
  • 298
« Reply #12 on: May 03, 2013, 01:39:24 pm »
Same way it does with a 70 or 90 alt.
1993 TD B3 Sedan
Reply #13May 03, 2013, 03:13:23 pm
bbob203
  • 1789
« Reply #13 on: May 03, 2013, 03:13:23 pm »
i didnt know there were 120amp alts for the aaz? The tdi didnt have a w terminal so i had to use a 90amp for my mtdi.
03 Jetta wagon TDi
Reply #14May 13, 2013, 10:18:06 am
Big Daddy Roth
  • 298
« Reply #14 on: May 13, 2013, 10:18:06 am »
Up
New injectors and the IP just came back from a check-up at Giles.
1993 TD B3 Sedan
