Author Topic: injector diagram? the parts fell out!  (Read 5446 times)
March 16, 2013, 02:42:07 pm
the4ork
  • 331
« on: March 16, 2013, 02:42:07 pm »
i was removing my nozzles per a pdf i found online and i clumsily let everything fall out of the injector body.
so now i dont know how all the springs and shims go back together.
a parts breakdown would be much appreciated after my failed search
Reply #1March 16, 2013, 03:53:50 pm
410
  • 581
Re: injector diagram? the parts fell out!
« Reply #1 on: March 16, 2013, 03:53:50 pm »
Just take apart another one carefully. ;D
Reply #2March 17, 2013, 02:51:46 pm
« Reply #2 on: March 17, 2013, 02:51:46 pm »
Edit: My post was not helpful. DELETED haha
« Last Edit: March 17, 2013, 04:57:56 pm by 8v-of-fury »
Reply #3March 17, 2013, 03:36:11 pm
« Reply #3 on: March 17, 2013, 03:36:11 pm »
The TDI injectors are a bit different.
Reply #4March 17, 2013, 04:57:05 pm
« Reply #4 on: March 17, 2013, 04:57:05 pm »
heh.. TDI section. My bad.
Reply #5March 17, 2013, 04:58:29 pm
Reply #6March 25, 2013, 11:17:38 am
the4ork
  • 331
« Reply #6 on: March 25, 2013, 11:17:38 am »
that site doesnt help, i need to know what order to put all the parts together inside the injector body, not just tne nozzles. I got overly excited when i got them apart and picked the injector body up in a way to move it out of my way where everything just slid right out of it :(
Reply #7March 25, 2013, 01:12:37 pm
« Reply #7 on: March 25, 2013, 01:12:37 pm »
You might try to give member Jim Foo a shout, he has some pix here of the DI injectors open:
http://www.vwdiesel.net/forum/index.php?topic=11948.msg85947#msg85947
(He hasn't been around for a year or so...)
He has a Rover/TDI site: http://www.66rover.com/
Closest thing I got is a diagram from the Bosch yellow-book:
Reply #8March 26, 2013, 03:34:14 pm
« Reply #8 on: March 26, 2013, 03:34:14 pm »
If you take a picture of all the pieces laid out neatly I might be able to tell you the order.
Reply #9March 26, 2013, 10:51:11 pm
the4ork
  • 331
« Reply #9 on: March 26, 2013, 10:51:11 pm »
I took another one apart and copied it, the second one was way easier to open up, dang the luck, I would take the hardest one to open up out and then drop all the innerds!!!
Reply #10March 27, 2013, 04:19:23 am
« Reply #10 on: March 27, 2013, 04:19:23 am »
Did you maybe take a pic....?
Reply #11March 31, 2013, 08:16:16 am
the4ork
  • 331
« Reply #11 on: March 31, 2013, 08:16:16 am »
