Author Topic: W Terminal low voltage reading  (Read 16396 times)
March 09, 2013, 02:18:38 pm
overdrivegear
  • 120
« on: March 09, 2013, 02:18:38 pm »
Hi Everyone, I'm attempting to use the Dakota Digital DSL-1 signal converter for my 87 Cabriolet diesel swap (out of an 86 Jetta).  I'm running into a problem with the voltage off the W Terminal.  The signal converter is meant to take in an AC voltage of 1-20VAC and my W-Terminal is only putting out 0.2-0.4 VAC @ ~200-250 Hz (idle).  Obviously the frequency is proportional to the engine speed but the voltage shouldn't be.  I was expecting to see somewhere around 10VAC.  My alternator works great so I don't see what the issue is.  I've checked and cleaned connections to the spade off the back of the alternator and that's not the issue.
I don't know if it is related but I modified this diesel alternator (http://forums.vwvortex.com/showthread.php?4308948-Re-volting-idea-for-regulators) and I'm getting 14.80 VDC at the battery.  It's great.  I cannot imagine that this is related to the low voltage at the W-terminal.  Hopefully not because I like having my voltage indicator pegged almost all the way to the right.
Can anyone help explain what is going on here?
1985 Westy Golf 1.6 NA
1987 Cabriolet (soon to be 1.6 NA)
Reply #1March 09, 2013, 02:35:02 pm
92EcoDiesel Jetta
Re: W Terminal low voltage reading
« Reply #1 on: March 09, 2013, 02:35:02 pm »
The W terminal output is taken before rectification by the diodes. I get different readings on the w terminal depending on the volt meter I use. Try a different meter.
Reply #2March 09, 2013, 03:05:18 pm
« Reply #2 on: March 09, 2013, 03:05:18 pm »
Voltage varies with engine speed... hence the need for a voltage regulator.
And, what I think is happening, is that your alternator is producing a "square wave." Your meter is expecting something more like a sine wave and doesn't know what to make of a square wave. I think car alternators produced something like a square wave to prevent voltage "ripple" after rectification, or else you would have a DC voltage that varies according to the frequency of the AC input... this is what you get with household appliances that use AC/DC adapters.
Reply #3March 09, 2013, 03:14:22 pm
92EcoDiesel Jetta
« Reply #3 on: March 09, 2013, 03:14:22 pm »
Yes, voltage should increase with increasing RPM. Dumb question: Did you have your meter set on the AC scale? Check house voltage to make sure it is working.
Reply #4March 09, 2013, 03:18:06 pm
« Reply #4 on: March 09, 2013, 03:18:06 pm »
Another dumb question... did you ground your meter?
Reply #5March 09, 2013, 04:35:24 pm
overdrivegear
  • 120
« Reply #5 on: March 09, 2013, 04:35:24 pm »
The voltage only marginally changes with RPM and the frequency is the thing that changes with RPM.
I know the signal is a square wave and I do have it set on AC voltage and toggle over to check frequency.  Yes my multi-meter is grounded and it's a rather expensive Fluke.
Reply #6March 09, 2013, 04:41:11 pm
overdrivegear
  • 120
« Reply #6 on: March 09, 2013, 04:41:11 pm »
I just saw this thread:
http://www.vwdiesel.net/forum/index.php?topic=31316.0
Says voltage does not change with RPM.  Vincent was getting 8 VAC.
Reply #7March 09, 2013, 05:20:56 pm
« Reply #7 on: March 09, 2013, 05:20:56 pm »
I'm going to have to take a look at this with my meter then, this has got my curiosity going.
That kind of makes sense with these alternators now that I think about it, the voltage regulator works on the un-rectified a/c voltage I would think. 8 volts sounds about right, considering it's a 3 pole system, right, so √3 x 8 = 13.86 volts which is where it should be... unless my understanding of this stuff is off.
Reply #8March 09, 2013, 05:22:13 pm
« Reply #8 on: March 09, 2013, 05:22:13 pm »
They use capacitors to filter out the noise,  not sure what type of signal the w terminal should have but square or sine would read the same because it just reads the low to the peak difference.  I'm thinking maybe the alternator isn't excited or u have 1 dead leg but I would think your alternator wouldn't charge properly then
Reply #9March 09, 2013, 05:35:32 pm
« Reply #9 on: March 09, 2013, 05:35:32 pm »
OK, I'm reading 7.8-7.9 volts and 200-800 hz (going from 800 to about 2500 rpm).
Fluke meter Model 175. Incidentally, my Fluke will not zero at a/c open circuit but will read like 0.02-0.05 at ranges under 6v and 0.2-0.5 at ranges above... This behavior, according to my Fluke manual, is normal.
I think what you have here is an open circuit. :(
edit: I should mention that I read nothing until the alternator excites...
« Last Edit: March 09, 2013, 05:37:59 pm by bajacalal »
Reply #10March 09, 2013, 08:32:56 pm
overdrivegear
  • 120
« Reply #10 on: March 09, 2013, 08:32:56 pm »
My Fluke behaves the same also (not zero at open circuit).  But I don't think I have an open circuit when connected to the W terminal because I'm still reading 'a' voltage (just not the right amount) and the frequency changes as it should with RPM.  I'm going to tear down this alternator tomorrow in search of a dirty connection internally.
But yeah, my alternator charges is pumping out 14.80 V at the battery with no load so it's charging my system very very well.  I really hope it's just a bad connection because I can't stomach replacing a whole alternator over a faulty W terminal...
Reply #11March 09, 2013, 09:44:41 pm
92EcoDiesel Jetta
« Reply #11 on: March 09, 2013, 09:44:41 pm »
If you're able to read frequency how can it be a bad connection? Something weird is going on.
Reply #12March 10, 2013, 10:27:33 am
overdrivegear
  • 120
« Reply #12 on: March 10, 2013, 10:27:33 am »
There could be a bad internal connection where there is potentially a significant voltage drop but what little signal that does exist can have it's frequency read.
Reply #13March 10, 2013, 11:20:07 am
92EcoDiesel Jetta
« Reply #13 on: March 10, 2013, 11:20:07 am »
 If that's the case no need to take the alternator apart yet. Measure the resistance of the W terminal (diodes) to the D+, B+ and ground terminas and compare to a good diode from Radio shack (1N4001 etc). Should be high resistance (meg ohms) one polarity and around 3 k ohms the other polarity.
« Last Edit: March 10, 2013, 11:38:28 am by 92EcoDiesel Jetta »
Reply #14March 10, 2013, 02:42:47 pm
overdrivegear
  • 120
« Reply #14 on: March 10, 2013, 02:42:47 pm »
Here is what I'm working with:
I have taken apart the alternator and cleaned up everything, re-tested and still have the same result.
Unless I'm missing something, I don't have a D+ terminal
Here it is with the back off:
Then my modified voltage regulator to get me an extra half volt:
