tdi egr and ecu issue
by
on 06 Mar, 2013 10:29
2000/1999.5 ALH golf
cleaned a terrific amount of sludge from the egr, intake and runners after the car went into limp.
Car is dramatically faster now but still in limp mode...
I also snapped the MAF diaphram arm ... so i wired it open is that ok? My aaz didn't need one
tons of hard carbon bits must regularily go through the engine because of the egr... such a good idea.... in theory.
#1
by
on 06 Mar, 2013 11:44
I think the reason EGR buildup is so bad is that none of the carbon leaves the intake.
I'll bet $2 its a MAF problem.
#2
by
shorttimer
on 06 Mar, 2013 17:10
I'm eliminating the EGR on my AAZ build. Just found a 1.6TD exhaust manifold. Direct swap with no EGR.
#3
by
on 06 Mar, 2013 20:46
Yeah that's how I had my last car. So anyways, I disconnected the battery for an hour and tried again... still goes into limp. Why or how does that valve in the intake help the engine?
#4
by
on 06 Mar, 2013 20:51
Sorry, do I mean maf? Its the valve that's part of the egress valve but not the exhaust valve the big one on the diaphragm.
#5
by
on 06 Mar, 2013 21:06
(MAF) normally pertains to the Mass Airflow Sensor, and the computer will always *** a brick if it isn't working.
On an ALH, you might be talking anti-shudder (ASV) or Exhaust Gas Recirculation(EGR), or conceivably the VNT actuator.
If you don't have means of checking the OBD codes, you should at least look onto an ELM scan device.
OK, my alphabits are all wore out now.
#6
by
on 06 Mar, 2013 23:00
the vnt actuator? yes this is the thing i broke i believe. it looks like a throttle body...
i broke the arm that comes out of the black diaphragm in the left of this image
#7
by
on 06 Mar, 2013 23:21
Anti Shudder valve, I'm not sure the ECU can detect that...
Check you didn't poop loose a vac line behind the intake, maybe on one of the N75 valves back there.
Bit of carbon keeping the EGR from closing? -plunger opposite the spaceship in your palm
Ruptured EGR diphram? - put a hose the the bit in your palm in the pic, and suck or blow, if it leaks, it's toast.
Looks like it was due for a cleaning.
#8
by
on 07 Mar, 2013 10:36
I noticed the car shudders a tad when I turn it off. Doesn't bother me and for $350 its gonna have to. I think I could have mixed up the vac lines. Can someone snap a pic for me? Or post one if they have one?
#9
by
on 07 Mar, 2013 10:45
And of the two sensors that are back there. One is longer than the other so I think I got it right but I don't know what is now throwing the CEL. Hmmm at least the diaphram will be easy to test. If the valve is stuck or broken do you guys recommend I replace it or remove it?
The intake was way more plugged than that. No wonder I thought the car was so slow. I did the burn method - works superb. Just keep a rag and a bucket of water with you.
I checked the valves at the back all are connected.
I'll have to remove it again and see if its stuck or what.
After I start the car I can get to almost 3,000 rpm before it limps and its way faster now until the CEL trips. It just cuts boost and makes the car smoke black like crazy.
#10
by
on 07 Mar, 2013 13:27
It will do exactly that if the N75 for boost control isn't hooked up, or is plumbed the wrong way. Checl both ends of the little hoses, they get pretty crispy after the first decade or so.
Can you get Q-bond at your local auto store? It works great for fixing plastic craps like that arm.
Bad EGR valve will give constant check lamp unless you can turn off EGR request in VAG-COM
#11
by
on 07 Mar, 2013 18:53
Okay. I have a couple meters of replacement line. Checked what I could find and looks to be all connected but I don't know that its correct. Can anyone verify the position of them?
#12
by
on 07 Mar, 2013 18:54
I burnt the carbon off the valve but I wrapped the diaphragm in an ice cold soaking wet towel. Ill try and get my lips on there and see if its still bust.
#13
by
on 08 Mar, 2013 15:45
Update, the diapram doesn't leak if I blow or suck on the hose. One of the charge pipes was loose. Fixed that and that cured the smoke and most of the power loss bit the CEL is still coming on after about 30 seconds of running.
#14
by
on 08 Mar, 2013 19:56
If you could use a test light on the Glow Plugs. I know it is weird to say, but mine went like that. Fine before I started messing with it and after had the cel? Or take it to a place to run the code.
