Author Topic: Turbo Diesel in VA!!  (Read 6778 times)
Reply #30March 05, 2013, 08:10:19 pm
camboscams
  • 324
Re: Turbo Diesel in VA!!
« Reply #30 on: March 05, 2013, 08:10:19 pm »
Yes, any cracks in the precup are a big problem - probably the biggest problem faced with the IDI engines.  They can grow very quickly and once the prechamber is cracked through it will hammer into the piston destroying both the piston and head.  Sometimes the pieces will fall into the cylinder destroying the rod and block as well.
I'm okay with what you have said here, so does anyone know where to get new pre-cups?
81' White 1.6l Rabbit 4dr Holseted
72' Ford F-250 390cid
2014 JSW 2.0L TDI Stg 2, CP3 HPFP
Reply #31March 05, 2013, 08:29:22 pm
RustyCaddy
  • 387
« Reply #31 on: March 05, 2013, 08:29:22 pm »
You will probably want the pre-cups made for turbo diesel engines.  They have a triangle stamped in them, facing the cylinder bore.
Check the search function...someone found some online a while back...or maybe they were for an NA?
Reply #32March 05, 2013, 10:01:26 pm
  • 7834
« Reply #32 on: March 05, 2013, 10:01:26 pm »
YEP
Reply #33March 05, 2013, 10:18:01 pm
Jagerauto
  • 144
« Reply #33 on: March 05, 2013, 10:18:01 pm »
I took a closer look. The one in question is hard to tell if its a crack, looks more like a scratch.. But I'm not positive. It does not appear to have a gap like a crack would. On #4 pre cup there does appear to be a super dooper small crack.
Leaky injectors cause them to crack. At least that's what I was told. Call Frank Irving he should be able to tell you where to find them, as they are something he deals with on a regular basis. He knows where to get AAZ ones as well. I would think they would all be the same.. But I guess not?
Reply #34March 05, 2013, 10:51:48 pm
camboscams
  • 324
« Reply #34 on: March 05, 2013, 10:51:48 pm »
Frank Irving? Could you elaborate?
Reply #35March 05, 2013, 11:19:47 pm
Jagerauto
  • 144
« Reply #35 on: March 05, 2013, 11:19:47 pm »
Google Franks TDi's
Reply #36March 11, 2013, 12:22:15 am
Jagerauto
  • 144
« Reply #36 on: March 11, 2013, 12:22:15 am »
Up
Reply #37March 11, 2013, 02:08:13 pm
  • Administrator
« Reply #37 on: March 11, 2013, 02:08:13 pm »
Google Franks TDi's
I personally have googled that like crazy but I can't seem to find any sort of business or anything.  Got an actual link?
Reply #38March 11, 2013, 11:18:30 pm
Jagerauto
  • 144
« Reply #38 on: March 11, 2013, 11:18:30 pm »
Phone number 417 232 4634
He does not have a website, old school guy.
Fixmyvw.com
