Time to start assembling 1.5 TD / 1.9L Franken Diesel.
Pages:
15
16
17
18
19
20
21
22
25
Topic: Time to start assembling 1.5 TD / 1.9L Franken Diesel. (Read 109617 times)
Reply #255
September 19, 2013, 08:08:03 am
Jetmugg
Re: Time to start assembling 1.5 TD / 1.9L Franken Diesel.
Reply #255 on:
September 19, 2013, 08:08:03 am »
OK, I've got something hopefully mean, and definitely green in the trailer.
Dyno test & tune is tonight. I have a GoPro on the roll cage, and a separate camera to shoot video from outside the truck.
Steve.
Reply #256
September 19, 2013, 09:58:25 am
Reply #256 on:
September 19, 2013, 09:58:25 am »
don't forget to report some numbers in real time
i am so anxious
Reply #257
September 19, 2013, 12:12:39 pm
Jetmugg
Reply #257 on:
September 19, 2013, 12:12:39 pm »
I'll have my GoPro installed in the truck's cab, a second video camera outside the vehicle, and my iPhone in my pocket.
I'll try to post numbers as soon as they are available, with as much follow-up video and dyno sheets as possible.
Steve.
Reply #258
September 19, 2013, 12:56:07 pm
Reply #258 on:
September 19, 2013, 12:56:07 pm »
also just noticed your diesel dodge pick up is pulling your diesel dodge pick up.
Reply #259
September 19, 2013, 01:05:01 pm
Jetmugg
Reply #259 on:
September 19, 2013, 01:05:01 pm »
Yep, and I have a diesel Mercedes Benz waiting at home. I'm all diesel at this point.
Reply #260
September 19, 2013, 02:09:06 pm
Reply #260 on:
September 19, 2013, 02:09:06 pm »
Best of luck with your pull.
Will this make her a dyno queen till she gets out on the salt?
Reply #261
September 19, 2013, 05:21:56 pm
Reply #261 on:
September 19, 2013, 05:21:56 pm »
And? And?
Reply #262
September 19, 2013, 05:26:04 pm
Reply #262 on:
September 19, 2013, 05:26:04 pm »
Quote from: RabbitJockey on September 19, 2013, 05:21:56 pm
And? And?
And?
Round 2
Reply #263
September 19, 2013, 07:03:31 pm
Reply #263 on:
September 19, 2013, 07:03:31 pm »
I dont want to stay up past my bed time for this but i will if i have to
Reply #264
September 19, 2013, 07:26:41 pm
Jetmugg
Reply #264 on:
September 19, 2013, 07:26:41 pm »
167hp 4600rpm
Reply #265
September 19, 2013, 08:11:53 pm
410
Reply #265 on:
September 19, 2013, 08:11:53 pm »
Awesome!
Toyota truck 4x4 with Mtdi, M-vnt gt1749va, 11mm pump, fmic, smog .216 nozzles. Sold!
Reply #266
September 19, 2013, 09:13:39 pm
Jetmugg
Reply #266 on:
September 19, 2013, 09:13:39 pm »
I made 4 or 5 pulls (can't remember exactly). I will have video(s) loaded up tomorrow, with screenshots of the dyno results. I'll have to wait for the reports to be emailed to me.
My boost controller wasn't doing what I wanted it to (because I didn't have it plumbed correctly).
The dyno at Ranken Technical College was pretty sophisticated. The instructor plugged in some values for weight of the Rampage, some aerodynamic estimates, estimated altitude data for Bonneville. This was all intended to load the dyno as if I were actually on the salt flats.
I ran up through 1st, 2nd, 3rd, and into 4th gear. We started all the pulls at about 2000 rpm, then I rolled into the throttle until 5500 rpm or so.
With 30 pounds of boost, the turbo power hit HARD! Even in 4th gear, it pulled very, very strong, up to 120 mph on the dyno.
I'll take some time to upload videos from the external camera, GoPro camera, and probably a few still photos. It was a very good night!
All in all, I was extremely pleased with the performance of the whole setup.
Reply #267
September 20, 2013, 04:01:00 am
Reply #267 on:
September 20, 2013, 04:01:00 am »
That is pretty impressive at such a low number RPM. I figured in the 1.5 you would have a little more than that but it would be in the low 5,000 rpm to 5,500 rpm range. Did you turn up the fuel at all or just leave the screw where it was. Either way that is 27hp that you didn't think you had and at a lower rpm. So you may not have to run it as hard as you thought?
How many miles do you have on it now and does it feel nice and freed up or is it still really tight?
Round 2
Reply #268
September 20, 2013, 04:26:07 am
Reply #268 on:
September 20, 2013, 04:26:07 am »
well stock, the 1.5 made 48hp. so you have made 3.5 times that at the wheels rather than the crank, that is very impressive. it will be interesting to see the dyno plots too. but even more interesting to see you shatter the bonneville record. it'd be sick if you could beat the 2.0 record with your 1.5
Reply #269
September 20, 2013, 05:21:05 am
Jetmugg
Reply #269 on:
September 20, 2013, 05:21:05 am »
I think I could have spun more rpm's with a lower gear ratio in the trans.
I hit 120 mph on the road-simulation dyno, pulling a simulated load (as if it were actually running on the salt flats).
With lower gearing, it definitely would have hit higher engine rpm's.
On paper, and on the dyno, I should be able to be competitive against the existing record. Of course, the kicker is that the race isn't run on paper or on the dyno. I have to make it happen on the salt flats, and anything can happen out there.
Steve.
Pages:
15
16
17
18
19
20
21
22
25
