Author Topic: Time to start assembling 1.5 TD / 1.9L Franken Diesel.  (Read 110296 times)
Reply #240September 04, 2013, 11:26:33 am
Jetmugg
  • 530
Re: Time to start assembling 1.5 TD / 1.9L Franken Diesel.
« Reply #240 on: September 04, 2013, 11:26:33 am »
I'm getting my mind around it.
There is one more meet at Bonneville this year - scheduled for Sept 30th - October 4th.  I'm setting my sights on that week.
Steve.
Reply #241September 04, 2013, 01:10:02 pm
flowmastergfunk
  • 129
« Reply #241 on: September 04, 2013, 01:10:02 pm »
Absolutely wonderful build! I am rootin for ya! Most turbo talk is still greek to me, but one day I will have the chance to dive in! When funding permits, I will learn ;)
Reply #242September 04, 2013, 03:10:01 pm
« Reply #242 on: September 04, 2013, 03:10:01 pm »
Hey atleast that gives you more time for some shake down and to get the engine broken in and see what rpms it is strongest at
You have the whole forum cheering for you.  This is definitely one of the best builds to grace this forum.
Reply #243September 04, 2013, 03:53:57 pm
« Reply #243 on: September 04, 2013, 03:53:57 pm »
That stinks and is good. If you get it broken in it will run better but you could have been racing this weekend. Oh well. I am cheering all the way for you. Start ripping down the road on it and get 1,000 or more miles on it, you have a month.
Reply #244September 04, 2013, 04:08:24 pm
« Reply #244 on: September 04, 2013, 04:08:24 pm »
Bitter sweet indeed. I'm looking forward to seeing your "extra" updates as a result of the extra time.
Reply #245September 04, 2013, 05:21:20 pm
  • 4553
« Reply #245 on: September 04, 2013, 05:21:20 pm »
No such element as Extra Time.  Like unobtainium.  All time is sucked into the void of usefulness and thus productivity spins the world around.
Too bad on the cancel but yes bittersweet if you don't blow it up between now and then.......
\\\\Practicing\\\\\
Reply #246September 04, 2013, 08:10:45 pm
RustyCaddy
  • 395
« Reply #246 on: September 04, 2013, 08:10:45 pm »
Mannnnnnn...... :(
But good...make that great things come to those who wait (whether by choice or not as the case may be)
Reply #247September 04, 2013, 09:13:46 pm
flowmastergfunk
  • 129
« Reply #247 on: September 04, 2013, 09:13:46 pm »
looks like I chimed in a little bit late :( your time will come!
Reply #248September 18, 2013, 08:34:56 am
Jetmugg
  • 530
« Reply #248 on: September 18, 2013, 08:34:56 am »
It's going on the chassis dyno at a local Technical College tomorrow night. ;D
I will be pleased if it can lay down over 140 hp at the wheels.  I'd love to be surprised with a larger number, but that would be a very strong start.
Steve
Reply #249September 18, 2013, 10:02:40 am
« Reply #249 on: September 18, 2013, 10:02:40 am »
will you be able to tweak boost and fueling during the tests?
how much boost are you currently running?
 ;) ;) ;)  can't wait to hear the results.
Reply #250September 18, 2013, 10:51:24 am
Jetmugg
  • 530
« Reply #250 on: September 18, 2013, 10:51:24 am »
The fuel screw is essentially maxxed out right now.  I can definitely adjust the wastegate settings, and pump timing between dyno pulls.
I'll have a friend with a video camera along for the testing, and I have a GoPro camera mounted to the roll cage, which I'll keep pointed at the gauges.
Steve.
Reply #251September 18, 2013, 10:58:30 am
« Reply #251 on: September 18, 2013, 10:58:30 am »
Itd be interesting to see different boost levels.  When powered by spearco dynoed his he went at multiple boodt levels,  it was interesting at low boost 10psi or so his power did not drop off at all as he approached 6k.
Reply #252September 18, 2013, 11:09:27 am
Jetmugg
  • 530
« Reply #252 on: September 18, 2013, 11:09:27 am »
It will be very fun, exciting, and nerve wracking, all at the same time.
Reply #253September 18, 2013, 11:18:58 am
« Reply #253 on: September 18, 2013, 11:18:58 am »
Reply #254September 18, 2013, 03:51:38 pm
« Reply #254 on: September 18, 2013, 03:51:38 pm »
My guess if we are taking them is 175hp-190hp. Hope you make it cannot wait until I see what you did and when you get to run.
Remember too I think you will have 5-10hp more once it is good and broken in/loosened up and that is what my guess is for.
« Last Edit: September 18, 2013, 04:02:39 pm by theman53 »
