Author Topic: Porting a 1.6 head  (Read 7934 times)
February 14, 2013, 06:04:02 am
TUFFY
  • 104
Porting a 1.6 head
« on: February 14, 2013, 06:04:02 am »
Hi, I am building a 1.6 for tractor pulling. I will need to push it pretty hard to compete. Going to port a 1.6 head. On a turbo engine should I open up the exhaust side a bunch as well as the intake side?
 I am hoping to run 40+ psi of boost if I can get enough fuel into it.
Reply #1February 14, 2013, 12:07:54 pm
bbob203
  • 1789
Re: Porting a 1.6 head
« Reply #1 on: February 14, 2013, 12:07:54 pm »
 :o EYES ON THIS THREAD!
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #2February 14, 2013, 09:03:25 pm
TUFFY
  • 104
« Reply #2 on: February 14, 2013, 09:03:25 pm »
Hopefully I can post a video this summer of it running good, or not as the case may be lol.
Reply #3February 14, 2013, 10:10:43 pm
Reply #4February 15, 2013, 08:32:33 am
Alcaid
  • 549
« Reply #4 on: February 15, 2013, 08:32:33 am »
If it's a hydro head put in some AAZ intake valves. They are the same length as 1.6TD but 2mm bigger (both 7mm and 8mm stem diameter available)
'10 VW Passat 1.6TDI Highline
Reply #5February 15, 2013, 09:03:14 am
bbob203
  • 1789
« Reply #5 on: February 15, 2013, 09:03:14 am »
do valve seats need to be recut if u p&p a head?
03 Jetta wagon TDi
Reply #6February 15, 2013, 09:16:38 am
justiz00
  • 54
« Reply #6 on: February 15, 2013, 09:16:38 am »
Is there a benefit to going to 7mm instead of 8mm (less stem to block airflow, etc.)?
Reply #7February 15, 2013, 09:39:21 am
Alcaid
  • 549
« Reply #7 on: February 15, 2013, 09:39:21 am »
Yes, better flow, but it requires changing the valve guide, valve seal, locks and retainer.
Reply #8February 15, 2013, 07:17:56 pm
« Reply #8 on: February 15, 2013, 07:17:56 pm »
bbob.. yes... need to remove guides to port it properly.. guides = recut, so when valves lapped in it on fresh surface.. if your doing it right...
any one can half arss it.. but for what he doing.. skimp = fail..
Reply #9February 15, 2013, 09:33:58 pm
BoostedOne
  • 63
« Reply #9 on: February 15, 2013, 09:33:58 pm »
If he has a hydro bottom end, wouldn't he come out ahead just using an entire AAZ/1Y etc any 1.9 head then a PD150 intake?  The 1.9 D ports look SOOOO much better than the 1.6.
Scott
82 Caddy 1.9 IDI
Reply #10February 16, 2013, 12:54:50 am
Alcaid
  • 549
« Reply #10 on: February 16, 2013, 12:54:50 am »
Upsides and downsides with the Franken combo, the valve chamfer around the valves in the head does not really match up with the 1.6 bore, neither does the prechamber port end up in the correct location. But it flows well anyway. I guess this might explain some of the knocking noise one sees on the Frankens.
For a daily driver I would use a 1.6 head to keep the easy cold starts and for less knocking sounds. For a full race engine, the 1.9 heads have their strength in the fact that they lower compression ratio alloeing more boost.
Both heads have massive gains available through porting!
Reply #11February 16, 2013, 05:55:51 am
TUFFY
  • 104
« Reply #11 on: February 16, 2013, 05:55:51 am »
I have a solid lifter engine.
Reply #12February 16, 2013, 06:26:09 am
TUFFY
  • 104
« Reply #12 on: February 16, 2013, 06:26:09 am »
Thanks for all the info and advice. I am starting out with a 1.6 head because that is what I have. I don't want to stick a ton of money into this until I see how it competes.
Can I put 1.9 intake valves in a solid lifter 1.6 head? I don't have my head apart yet so I don't know what size the guides are.
Reply #13February 16, 2013, 06:31:47 am
Alcaid
  • 549
« Reply #13 on: February 16, 2013, 06:31:47 am »
Solid lifter heads have different valves IIRC, meaning 1.9 valves won't fit :(
Reply #14February 17, 2013, 12:44:15 am
MJF
  • 581
« Reply #14 on: February 17, 2013, 12:44:15 am »
1.7, 2.0 and 2.4 engines has 36mm intake valves which fit. Exhaust valves are same size in all diesel engines.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
