cant find bolts for my AAZ
Pages:
Topic: cant find bolts for my AAZ (Read 6872 times)
Reply #15
February 16, 2013, 01:21:43 pm
paolomarks
Re: cant find bolts for my AAZ
Reply #15 on:
February 16, 2013, 01:21:43 pm »
Looking around abit I've found an ARP #204-5402 but that seems to be for the shorter 65mm length. Saw somewhere that a ARP #201-5001 for BMW 2.3 liter might work? Any confirmation on this. Paolo
Reply #16
February 20, 2013, 03:10:59 pm
paolomarks
Reply #16 on:
February 20, 2013, 03:10:59 pm »
So I gave ARP the specs on the longer AAZ mains and they replied that they have none for that application. I went ahead and bought some socket head cap screws. 2 questions for those of you who have used SHCS for the mains: Do you install washers between screw head and main caps? and what do you torque them to? Thanks, Paolo.
Reply #17
February 20, 2013, 08:28:52 pm
Reply #17 on:
February 20, 2013, 08:28:52 pm »
Last time I didn't use any, this time I used a grade 8 washer under mine. I used a torque value about 20% more than stock, since the 12.9 SHCS is about 25% higher tensile strength.
Round 2
Reply #18
February 21, 2013, 08:11:34 am
paolomarks
Reply #18 on:
February 21, 2013, 08:11:34 am »
Thanks , Paolo
Reply #19
March 20, 2015, 12:30:34 pm
ToddA1
Reply #19 on:
March 20, 2015, 12:30:34 pm »
Bumping an old thread....
I just pulled the main bolts to check out the bearings in JUST the caps. I did not pull the crank. The shells looked fine and rotating the crank, the same proved correct for the journals.
Anyhow, I have 65mm bolts with no shoulder under the hex head. I'm guessing these may have been replaced...?
Is the ARP 204-5204 a cure or a bandaid for the potential to crack the caps?
Would retapping the block be a better long term solution?
Are 65mm 12.9 bolts a comparable fix? i do understand that studs have better clamping ability.
I don't plan on building a crazy engine.
-Todd
Reply #20
March 20, 2015, 12:41:53 pm
Reply #20 on:
March 20, 2015, 12:41:53 pm »
No shoulder = stretch bolt, they are single use.
A set of factory AHU bolts will fit fine, are affordable and will do the job safely.
Reply #21
March 20, 2015, 12:46:12 pm
ToddA1
Reply #21 on:
March 20, 2015, 12:46:12 pm »
Aren't the AHU bolts 80mm? Not looking to retap the block if I can avoid it.
-Todd
Reply #22
March 20, 2015, 01:35:20 pm
ToddA1
Reply #22 on:
March 20, 2015, 01:35:20 pm »
I guess I didn't need to bump this thread.
I went out, reinstalled 2 main caps and grabbed a sliding caliper. Shot it down the bolt hole and measured slightly over 78mm. Did this a couple times. Apparently, my block had the shorter bolts installed for no reason.
Question... Is the 80mm that's mentioned an approximate bolt length? I definitely don't want the bolt bottoming out.
-Todd
Pages:
