Author Topic: cant find bolts for my AAZ  (Read 6871 times)
February 07, 2013, 02:59:17 pm
paolomarks
  • 146
« on: February 07, 2013, 02:59:17 pm »
i'M rebuilding my AAZ . Looking for a crankshaft bolt(holds the timing gear on) and a set of main bolts(tightens the crank caps down)  Who has them?   Thanks, Paolo
Reply #1February 07, 2013, 04:31:50 pm
Re: cant find bolts for my AAZ
« Reply #1 on: February 07, 2013, 04:31:50 pm »
The mains are tricky. They had 2 different mains. m10.-1.5x 65mm OR x 80mm. Since we have had 2 people in the last year blow up #2 main I would NOT run the 65mm mains. I would drill and tap them to 80mm and use an 80mm bolt. IIRC both had the 65mm mains that threw the rod cap. Any 12.9 grade socket head cap screw that size would work OR a normal Hex head cap screw 10.9 grade as that is what came from the factory.
The crank bolt is one time use Torque to Yield and can be had at the dealer or online. Same bolt as the AHU. NOT the same as ALH.
http://www.idparts.com/catalog/product_info.php?cPath=29_74&products_id=1212
Reply #2February 07, 2013, 08:20:53 pm
CrazyAndy
  • 739
« Reply #2 on: February 07, 2013, 08:20:53 pm »
theman53, are the designs for the main caps different between the two main bolts?
Also a good reference about crank bolts I found out.  Some older ones were not torque-to-yield, but you can tell which ones are by looking at the bolt head.  if there is a cylindrical nub on the end like this:
. . .then they are TTY.
I'm only saying this so that if you get a bolt that doesn't have a nub, you know they gave you the wrong one, like one for an older 1.6.
Reply #3February 07, 2013, 08:24:18 pm
« Reply #3 on: February 07, 2013, 08:24:18 pm »
Yes I was assuming since he asked that he has the TTY. Either way, the TTY can be used. If there is any place I think a TTY bolt is cool is right here on the crank sprocket.
As far as I know, no. The main caps are identical in everyway. The block was tapped deeper. There is plenty of meat to go the extra 15mm I guess.
Reply #4February 08, 2013, 04:54:12 am
CrazyAndy
  • 739
« Reply #4 on: February 08, 2013, 04:54:12 am »
Amen brother!  And I guess I should check my main bolt holes.  Thanks for bringing that up.
Reply #5February 12, 2013, 09:53:51 pm
BoostedOne
  • 63
« Reply #5 on: February 12, 2013, 09:53:51 pm »
I just put the sprocket on my 1.9.  I first tried the old crank sprocket bolt out of an early 11mm block 1.6 and it was too small.  But I found the one out of my MkII 12mm hydraulic motor fit perfect.  And its a 6 point head so I guess i can reuse it as much as I want.
Scott
82 Caddy 1.9 IDI
Reply #6February 13, 2013, 03:50:48 pm
« Reply #6 on: February 13, 2013, 03:50:48 pm »
Who had the #2 main bearing fail?  Were the using the shorter conventional re-useable bolts or the longer TTY ones?
Reply #7February 13, 2013, 07:18:36 pm
« Reply #7 on: February 13, 2013, 07:18:36 pm »
Smoking eddy and Jimfoo both had the #2 main cap let go and both IIRC had the 65mm main bolts.
Reply #8February 14, 2013, 06:56:41 am
« Reply #8 on: February 14, 2013, 06:56:41 am »
Interesting.  The 1.6TD bolts are the same as the shorter AAZ bolts and I'm not aware of any issues.  I'm currently assembling an AAZ that has the shorter bolts and will consider the ARP mains.
Reply #9February 14, 2013, 07:04:07 am
« Reply #9 on: February 14, 2013, 07:04:07 am »
Hypothesis:
I think the 1.9 with the longer stroke has more inertia and pulls against the mains harder than the 1.6. Especially at the same rpm of the 1.6. The 1.9 also has more weight in the crank. Add several hundred thousand miles, a rebuild with good compression, maybe things get a bit tough? It would seem VW saw the issue and added 15mm to the bolts to correct it.
It doesn't happen often it seems but we had 2 in short order and when I make my AAZ into the TDI I am either going studs or tapping the hole deeper and longer bolts. I still need to find out if I have the shorter bolts or not before I do this.
Reply #10February 15, 2013, 09:01:12 am
paolomarks
  • 146
« Reply #10 on: February 15, 2013, 09:01:12 am »
Interesting information indeed.  I have the longer 80mm bolts in my AAZ which I'm assuming are TTY.  (The Bentley says to give them an extra 1/4 turn)   Where can I find replacement
TTY bolts?  If I decide to go studs,  anyone know the ARP part no.?   Thanks, Paolo
Reply #11February 15, 2013, 01:23:21 pm
« Reply #11 on: February 15, 2013, 01:23:21 pm »
Just an FYI, but I have not been at all impressed with the quality of the TTY main bolts, straight from VW they appear to be poorly made.  I just got a set and few of them are straight and in a set of 10, two were so bent that they bound noticeably on install.
They'd probably straighten when torqued, but it still seems disconcerting considering what can happen if they fail.
I seriously doubt VW went to the TTY bolts to address an issue, but rather to quicken initial assembly.  The TTY bolts rarely solve issues and sometimes create them (e.g. 2.1 WBX rod bolts...), but they do assemble quickly at the factory and increase parts sales...
« Last Edit: February 15, 2013, 01:26:51 pm by libbydiesel »
Reply #12February 15, 2013, 02:20:39 pm
homerj1
  • 433
« Reply #12 on: February 15, 2013, 02:20:39 pm »
Hate to say the Subject screams a Michael Scott , that's what she said?
sorry must be the Canadian beer... ;)
Reply #13February 15, 2013, 03:12:04 pm
CrazyAndy
  • 739
« Reply #13 on: February 15, 2013, 03:12:04 pm »
Bazinga.
So I have some main studs from Raceware for my AAZ already.  Based on this thread info, should I go ahead and get the main holes bored and tapped deeper?  What's the year/production cutoff for the 65mm mains application if anyone knows?
And I just realized that I never recommended a main bolt application in my FP' that said, I recommend studs if going for power.   ARP and as stated above Raceware sell 'em.  ARP also does hardened bolts, too.  Just thought I'd say that as I never did originally.
Reply #14February 15, 2013, 03:40:29 pm
paolomarks
  • 146
« Reply #14 on: February 15, 2013, 03:40:29 pm »
thanks for the responses.  Any one have the ARP # for 80mm AAZ Mains?  Paolo
