Author Topic: New to the forum but not my mk1's! *Caddy Build in Progress* *AAZ*  (Read 19208 times)
February 04, 2013, 08:27:51 pm
Jagerauto
  • 144
Hey guys my name is Hunter, I'm from Chesapeake, Va.
Had a diesel for a little over a year. Been building it for a year.. yes means I haven't driven it in a year, with the exception of h2o which ended badly.. Head was ruined when I got back home
Anyways I was building a 1.6TD Rabbit 4Dr, and this is close to when it was done, right before the bottom end ate itself and I started new..
To see the build thread see here: http://forums.vwvortex.com/showthread.php?5683133-Project-NOT-making-SOWO-2012.-Story-of-a-82-4dr-LS-and-a-1.6l-Turbo-Diesel
Now for the caddy.. Build thread here: http://forums.vwvortex.com/showthread.php?5920212-AAZ-Turbo-Diesel-Caddy-Build-*keeper*
When I bought it
Swapped the front suspension (not lowered) ans wheels/adapters
Removed fenders to find some rust..
The motor and 02J as it sits.. (changing color!!!!) Gold!!!
Removed all the undercoating! and POR15'd it all!
Cut a floor pan out of a donor jetta I have.
Thats where I'm at! I have not worked on it in a couple weeks. I need to get the sheet metal ready to weld in, call a buddy to come over and weld it.. call a paint guy, and get a nice cheap paint job.. ;)
Reply #1February 04, 2013, 08:42:31 pm
Re: New to the forum but not my mk1's! *Caddy Build in Progress* *AAZ*
« Reply #1 on: February 04, 2013, 08:42:31 pm »
How long did it take you to do those fender wells? seems like an easy couple days a piece..
Reply #2February 04, 2013, 08:56:10 pm
Jagerauto
  • 144
« Reply #2 on: February 04, 2013, 08:56:10 pm »
5hours straight each side. An iPod and a long playlist and your set. From what I can tell the fenders are the worst/thickest and therefore hardest. I plan to do the rears as well.
Reply #3February 04, 2013, 09:21:12 pm
« Reply #3 on: February 04, 2013, 09:21:12 pm »
Yeah, I was thinking about it.. but I have an extremely clean 84 Jetta. The only rust is one seam of the trunks floor, loovely lol.
Which is retarded,,, because for the 5 years I have been driving it the rear floor pans have been lakes.
Reply #4February 05, 2013, 09:23:24 am
Jagerauto
  • 144
« Reply #4 on: February 05, 2013, 09:23:24 am »
Pulled the trigger on the stage two cam!
Reply #5February 05, 2013, 01:20:46 pm
Jagerauto
  • 144
« Reply #5 on: February 05, 2013, 01:20:46 pm »
Received my CE2 harness/cluster today!
Reply #6February 05, 2013, 05:35:30 pm
CrazyAndy
  • 739
« Reply #6 on: February 05, 2013, 05:35:30 pm »
Looks like you've come quite a ways already.  Like I said in the other thread, old engine colors are too loud, go I'm glad you're taking the color in another direction.  So what will the CE2 harness and cluster do?
Car is definitely in good hands, so keep on keepin' on.
Reply #7February 05, 2013, 05:48:19 pm
Jagerauto
  • 144
« Reply #7 on: February 05, 2013, 05:48:19 pm »
I wanted to swap harness's because the old mk1 wiring had seen its share of jerry riggin, and it had issues.. So swapping to this ce2 harness will give me a newer harness, and the cluster matched with a corrado g60 speedo cable will screw right into the 02J. And the mk2 cluster is not hard to modify into a mk1 dash.
« Last Edit: February 05, 2013, 07:52:41 pm by 8v-of-fury »
Reply #8February 05, 2013, 05:49:03 pm
Jagerauto
  • 144
« Reply #8 on: February 05, 2013, 05:49:03 pm »
Not to mention if later on I wanted to do a tdi swap its so much easier with a ce2 harness.,
Reply #9February 05, 2013, 07:25:13 pm
bbob203
  • 1789
« Reply #9 on: February 05, 2013, 07:25:13 pm »
Even easier if it's mtdi 8)
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #10February 05, 2013, 07:54:04 pm
« Reply #10 on: February 05, 2013, 07:54:04 pm »
What wiring?? Haha. For anyone south of me you could even leave out GP wiring to clean it up.. -16C I can start my mtdi with no issue.. -23c she moans about it.. But itll start.
Reply #11February 05, 2013, 07:57:36 pm
Jagerauto
  • 144
« Reply #11 on: February 05, 2013, 07:57:36 pm »
Just something that made sense.. So it's happening.. Not to mention how easy wiring wise it is to add power windows/locks.. Ect.
Reply #12February 06, 2013, 12:25:38 pm
Jagerauto
  • 144
« Reply #12 on: February 06, 2013, 12:25:38 pm »
Ripped out the old crappy wiring harness.
Reply #13February 06, 2013, 12:39:48 pm
srgtlord
  • 797
« Reply #13 on: February 06, 2013, 12:39:48 pm »
haha rigging edited. We all know exactly what type of rigging you were talking about ;)
Reply #14February 06, 2013, 01:24:30 pm
Jagerauto
  • 144
« Reply #14 on: February 06, 2013, 01:24:30 pm »
My bad meant to use the white version "Jerry rigged" lol
