Author Topic: AAZ dual stage injectors - Opening pressures?  (Read 3650 times)
December 28, 2012, 06:26:42 am
Alcaid
  • 549
« on: December 28, 2012, 06:26:42 am »
Hi,
The first opening stage / pilot injection on these are 150-158bar according to Bosch spec, but what is the second stage set at?
Anyone got experience with running slightly higher opening pressures? I have a set that will be set up with the Bosio BNOSD308 "GTD" nozzles soon.
'10 VW Passat 1.6TDI Highline
Reply #1December 28, 2012, 09:55:55 am
Reply #2January 14, 2013, 04:41:48 am
Alcaid
  • 549
Re: AAZ dual stage injectors - Opening pressures?
« Reply #2 on: January 14, 2013, 04:41:48 am »
Anyone else got information on the second opening pressure? (preferably from a more official source than a forum post)
Anyone experimented with higher opening pressures on these?
Reply #3January 15, 2013, 10:48:00 am
« Reply #3 on: January 15, 2013, 10:48:00 am »
The 1.9AAZ has a higher break pressure than the AHU and ALH TDI?
I have heard all three 1.9's were 195 bar. The 2.5L 4 cylinder Land Rover I have heard rumored a 220 bar break pressure.
