Author Topic: r/s , timing belt side engine mount placement/ postioning  (Read 2142 times)
December 18, 2012, 06:50:25 am
madrogers
  • 165
« on: December 18, 2012, 06:50:25 am »
I looked and searched and could not find a different answer to how to postion the new rubber engine mount in the bracket. Found a vortex site that said put the  "Y" up , then ended with the "Y" down. Does someone have a pic or thread they can send me to. Putting a 1.6 td in my caddy soon and this is part of that process.  Thanks.
83 CADDY 1.6 TD WINTER
83 CADDY 1.9 AAZ SUMMER
Reply #1December 18, 2012, 08:11:56 am
Reply #2December 18, 2012, 12:47:28 pm
Re: r/s , timing belt side engine mount placement/ postioning
« Reply #2 on: December 18, 2012, 12:47:28 pm »
Also, bear in mind that the injection pump bracket parts are what determine timing belt tracking and once removed from the engine can often take a considerable amount of time to replace so the timing belt tracks properly.
Reply #3December 18, 2012, 12:58:39 pm
madrogers
  • 165
« Reply #3 on: December 18, 2012, 12:58:39 pm »
 thanks, that helps alot, there are no more replys to that discussion that should mean that every one is in agreement I will take the taking into advisment and keep an eye on it once it is running agian.
Thanks Mark.
Reply #4December 18, 2012, 03:09:52 pm
92EcoDiesel Jetta
« Reply #4 on: December 18, 2012, 03:09:52 pm »
Thanks Mark.
I had no timing belt tracking problems after replacing the engine mount bracket. Didn't know it's a potential problem when I did it.
