Author Topic: What clutch for 01 TDI?---some answers for MKIV clutch replacement  (Read 6231 times)
December 03, 2012, 07:10:23 pm
I know I need the SMF, but what disc holds up well? I don't want the 6 puck ceramic styles that are harsh on/off button engagement, but I would like it to handle some torque if I ever need it to.
I have a line on a SPEC clutch and wondered if anyone had tried one of them. How do the daily drive? It is the SV 362 in the link below that I can get a deal on.
 http://www.specclutch.com/cars/Volkswagen/Golf_III/1998/Single
I have had mine slip for a little bit and I am preparing for the worst. PO replace the DMF with another DMF setup 80,000 miles or so ago and I think it is giving in a bit.
« Last Edit: December 05, 2012, 08:26:11 am by theman53 »
Reply #1December 05, 2012, 03:50:43 am
G60ING
  • 170
    Corrado TDI
    • My VW Projects
Re: What clutch for 01 TDI?
« Reply #1 on: December 05, 2012, 03:50:43 am »
How much whp/wtq are you planning for the future. I'm running a stock mk3 sachs Tdi clutch with no issues. Then again I don't have crAzy power.
Reply #2December 05, 2012, 06:13:57 am
« Reply #2 on: December 05, 2012, 06:13:57 am »
This just in from TDI club...I have been searching for days...
      "I GOT IT!!!!!
So, after doing a little more digging using the link Yblocker provided and a little work in ETKA... you will all like this.
The AAA VR6 pressure plate in ETKA is part #021 141 025 F.
That cross-references to Sach's part #3082 231 031.
The TDI pressure plate in ETKA is part #074 141 025 B
You'll never guess what that cross-references to.
3082 231 031
YUP. Same damn pressure plate!!!!
SO, the answer is (runonbeer was unwittingly correct!) use the Mk3/B4 TDI clutch kit! The pressure plate is the same and the disk is rattle-free.
So, everyone remember the part number runonbeer referenced: K7003801
The hell with the VR6 kit!
Well, this has been enlightening."
From this thread
http://forums.tdiclub.com/showthread.php?t=340137&page=2
another good thread
http://forums.tdiclub.com/showthread.php?t=310218&highlight=smf+clutch
that is what I am going to go with.
« Last Edit: December 05, 2012, 06:16:47 am by theman53 »
Reply #3December 05, 2012, 06:17:18 am
« Reply #3 on: December 05, 2012, 06:17:18 am »
BTW I have a malone stage 1.5 in car and have stage 2 and 3 waiting.
Reply #4December 05, 2012, 06:38:03 am
bbob203
  • 1789
« Reply #4 on: December 05, 2012, 06:38:03 am »
Good info thanks. Looks like the g60 fw and tdi clutch kit is the way to go for what im doing.
« Last Edit: December 05, 2012, 06:42:46 am by bbob203 »
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #5December 05, 2012, 08:25:38 am
« Reply #5 on: December 05, 2012, 08:25:38 am »
http://forums.vwvortex.com/showthread.php?2703042-DIY-MKIV-VR6-Transmission-Removal-Clutch-Replacement&
I am just posting some links for myself and others whom maybe in for this job. The one above is VR but should be similar for all O2J / O2A trans.
 Also found out it isn't that heavy, so I will be lifting it out like my 020. http://forums.vwvortex.com/showthread.php?4664520-I-Was-Able-to-Weigh-these-020-o2o-02A-o2a-02M-o2m-transmissions-Transmission-Weight
Reply #6December 05, 2012, 11:39:25 am
Re: What clutch for 01 TDI?---some answers for MKIV clutch replacement
« Reply #6 on: December 05, 2012, 11:39:25 am »
I've had nothing but happy times with Southbend  clutches.
Reply #7December 05, 2012, 04:43:50 pm
« Reply #7 on: December 05, 2012, 04:43:50 pm »
Says it will cross reference to a Mk3 TDI as well, which is an 02A. Its all good, I think I will be getting one of these! Stage 2 at 365tq should suffice eh? ;)
Reply #8December 05, 2012, 06:02:09 pm
« Reply #8 on: December 05, 2012, 06:02:09 pm »
http://www.idparts.com/catalog/product_info.php?manufacturers_id=86&products_id=859&osCsid=q6tk1p5hmsvqrsbd7co3t886b4
Looks like that is what I maybe getting. I can get the SACHS on ebay for 160.00, but I really only want to do this once.
Reply #9December 05, 2012, 06:10:36 pm
« Reply #9 on: December 05, 2012, 06:10:36 pm »
Nice that kit will work with my stock Mk3 TDI flywheel when I eventually go 02A.. except the 02A swap for me is gonna be like a friggan $1500 ordeal...
