Author Topic: 81 Caddy starter motor question  (Read 14844 times)
December 02, 2012, 08:38:23 am
92EcoDiesel Jetta
« on: December 02, 2012, 08:38:23 am »
The starter in my Caddy maybe on the fritz and either needs rebuilding or replacement. I notice it is a bigger unit (physically) than the one in my 92 Eco. I have a low mileage spare starter (60K) from a 91 Eco (MK2). Will it fit in my MK1 Caddy?
Reply #1December 02, 2012, 08:42:26 am
Re: 81 Caddy starter motor question
« Reply #1 on: December 02, 2012, 08:42:26 am »
I put a MK2 starter in my caddy. It just has the extra portion on the flange for the MK2 Motor mount.
Might as well change the bushing too.
Reply #2December 02, 2012, 08:48:42 am
« Reply #2 on: December 02, 2012, 08:48:42 am »
I use mkii starters as well
Reply #3December 02, 2012, 08:53:12 am
« Reply #3 on: December 02, 2012, 08:53:12 am »
The smaller starters are heaps better than the big ones.
Reply #4December 02, 2012, 07:52:47 pm
92EcoDiesel Jetta
« Reply #4 on: December 02, 2012, 07:52:47 pm »
Bushing? What bushing? pic? p/n? Thanks!
Reply #5December 02, 2012, 08:06:34 pm
« Reply #5 on: December 02, 2012, 08:06:34 pm »
The bushing is a bronze sleeve that is pressed into the bellhousing, to accept the end of the starter shaft.
It is a normal wear-item, that if ignored can strand you, as the starter drags and beats-up the pinion & flywheel.
Some guys have simply threaded a bolt into the old one and pulled it out - drive in a new one with a wood block.
Reply #6December 02, 2012, 08:08:49 pm
Reply #7December 03, 2012, 05:26:40 am
« Reply #7 on: December 03, 2012, 05:26:40 am »
Fill it full of oil and press with your fingers and you get a pre lubed bushing. I had a writeup on here long time ago...
Reply #8December 04, 2012, 02:16:55 pm
92EcoDiesel Jetta
« Reply #8 on: December 04, 2012, 02:16:55 pm »
AutohausAZ #113301155
http://www.autohausaz.com/search/product.aspx?sid=nieuca45vwepvq55mpnd1h2k&partnumber=113301155
Thanks for the p/n. Ordering from Autohausaz takes a week for the $50 free shipping so I called Advance auto parts and gave them the VW p/n 113 301 155 and believe it or not they can order it and have it by Dec 7th for $1.73 ea. ! It's from a company by the name of IMC, probably the same one Autohausaz sells.
As far as tapping the bushing and pulling it out with a bolt can someone who has done it provide more specific info such as what size tap you used and what can go wrong? I took a look at a spare 020 transmission I have and that bushing has pretty thin walls and I am afraid of stripping the soft bronz if not done right.
Reply #9December 04, 2012, 02:34:53 pm
« Reply #9 on: December 04, 2012, 02:34:53 pm »
IIRC, when I changed the last one, I just cranked a long 12mm bolt into the old bushing and did some kind of ghetto slide-hammer action to pull it out.
Main things to watch: not to beat up the aluminum bore, and to drive the new bushing in straight, without dinging it up (hence the wood block).
Reply #10December 04, 2012, 03:49:34 pm
« Reply #10 on: December 04, 2012, 03:49:34 pm »
When I did it I just inserted the tap and kept turning until the bushing started spinning. Then I kept turning and pulled at the same time and it came out. Use the most course tap that you have.
Reply #11December 04, 2012, 03:51:35 pm
bbob203
  • 1789
« Reply #11 on: December 04, 2012, 03:51:35 pm »
ditto
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #12December 04, 2012, 09:08:20 pm
shorttimer
  • 121
« Reply #12 on: December 04, 2012, 09:08:20 pm »
This is on the 'to do' list on my Caddy/AAZ project. Love the cheap part, too.
Reply #13December 05, 2012, 06:33:12 am
« Reply #13 on: December 05, 2012, 06:33:12 am »
Reply #14January 07, 2013, 08:37:08 pm
92EcoDiesel Jetta
« Reply #14 on: January 07, 2013, 08:37:08 pm »
I made a plug gage the same diameter as the starter motor shaft and found the bushing in the Caddy tranny is not worn at all! It actually has less play than a new bushing! Saves me from having to R&R the bushing. I'll just grease it up. Pulling the starter was a breeze in the Caddy compared to a MK2. I'll be taking the starter apart to see what's wrong with it.
