Author Topic: Motor mounts  (Read 14310 times)
November 12, 2012, 05:01:42 pm
Rising
  • 385
Motor mounts
« on: November 12, 2012, 05:01:42 pm »
Does anyone upgrade the motor mounts on these diesels? Or will that just rattle my teeth out? My rear motor mount just broke and I need to replace it so I thought I might use the opportunity. Any recommendations? Or just new ones?
Sent from my ThunderBolt using Tapatalk 2
'84 Rabbit Diesel- 1.6D Stock
Reply #1November 12, 2012, 05:26:27 pm
bbob203
  • 1789
Re: Motor mounts
« Reply #1 on: November 12, 2012, 05:26:27 pm »
the only upgraded mounts will make it worse. get oem. only you could change out you k frame for a vr6 from an mk3 and change the bracket on your engine. thay may or may not rwduce vibration though.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #2November 12, 2012, 06:15:29 pm
Re: Motor mounts
« Reply #2 on: November 12, 2012, 06:15:29 pm »
Don't buy FEBI FEQ!! They are junk and will rattle your teeth out.
« Last Edit: November 13, 2012, 11:21:38 am by burn_your_money »
Reply #3November 12, 2012, 06:46:03 pm
Rising
  • 385
Re: Re: Re: Motor mounts
« Reply #3 on: November 12, 2012, 06:46:03 pm »
Would the vr6 kframe have a significant impact on anything or just an option? I think ill probably just go oem.
Don't buy FEBI!! They are junk and will rattle your teeth out.
Noted! I certainly don't want anything getting worse. Though my rattles aren't too bad.
Reply #4November 12, 2012, 11:43:08 pm
mystery3
  • 774
Re: Motor mounts
« Reply #4 on: November 12, 2012, 11:43:08 pm »
The prothane inserts are probably overkill, pretty big increase in nvh. I think next time I'll fill the mounts with some low durometer urethane myself and try that out. Is your front mount shimmed?
Reply #5November 13, 2012, 11:19:37 am
Re: Motor mounts
« Reply #5 on: November 13, 2012, 11:19:37 am »
You don't have a k-frame so don't worry about swapping that out.
I take back my FEBI comment, that's not who I used. I used FEQ
« Last Edit: November 13, 2012, 11:21:58 am by burn_your_money »
Reply #6November 14, 2012, 10:11:21 am
Rising
  • 385
« Reply #6 on: November 14, 2012, 10:11:21 am »
Uhmmm....
Nope?
Haha
Reply #7November 15, 2012, 11:37:12 pm
mystery3
  • 774
Re: Motor mounts
« Reply #7 on: November 15, 2012, 11:37:12 pm »
People make little plates and there are myriad diy options but the idea is to get the little cup that the front/snub mount sits in to be closer to the engine  or snug on the mount thus reducing the slop and tightening things up a bit.
Reply #8November 16, 2012, 09:20:02 am
jboogie13
  • 175
Re: Motor mounts
« Reply #8 on: November 16, 2012, 09:20:02 am »
essentially preloading all the mounts in the engine bay. i feel like that would cause premature wear on the rear mounts
Reply #9November 17, 2012, 12:04:51 am
mystery3
  • 774
Re: Motor mounts
« Reply #9 on: November 17, 2012, 12:04:51 am »
You're probably correct in your assumption but I think it's worth it. The front and rear are inexpensive and easy to change out and I hate slop in my driveline. I'm generally a big fan of poly and solid motor and transmission mounts on most vehicles.
Reply #10November 17, 2012, 06:14:59 am
jboogie13
  • 175
Re: Motor mounts
« Reply #10 on: November 17, 2012, 06:14:59 am »
every tried the non hydraulic mounts in the idi's? im not concerned with comfort in my vehicle so much as i am with it rattling itself apart, its already pretty buzzy in the cabin and im amazed the plaic pieces have lasted this long.
Reply #11November 17, 2012, 09:32:54 am
bbob203
  • 1789
Re: Motor mounts
« Reply #11 on: November 17, 2012, 09:32:54 am »
you problems will be worse.
03 Jetta wagon TDi
Reply #12November 17, 2012, 09:52:49 am
jboogie13
  • 175
Re: Motor mounts
« Reply #12 on: November 17, 2012, 09:52:49 am »
stock mounts it is!
Reply #13November 17, 2012, 09:52:56 pm
mystery3
  • 774
Re: Motor mounts
« Reply #13 on: November 17, 2012, 09:52:56 pm »
The OP and I are both driving mkI so I don't have any experience with hydraulic mounts.
Reply #14November 22, 2012, 09:02:01 pm
JamesT
  • 151
Re: Motor mounts
« Reply #14 on: November 22, 2012, 09:02:01 pm »
Don't try inserts. They just make it harsh. I have FEBI mounts on sides and rear, and some no-name mount on the front. It shakes a bit, but it doesn't feel like the car is coming apart.
93 Golf - AAZ with some fueling
78 Rabbit - 1.5 DIESEL (finally)
[(+)===o===(+)]
 (++\==o==/++)
