Author Topic: FS AAZ K14 turbo *SOLD*  (Read 8925 times)
November 03, 2012, 01:39:49 pm
rallydiesel
  • 1880
« on: November 03, 2012, 01:39:49 pm »
AAZ k14 (the larger compressor wheel type, aka the "good" one) for sale.
Great condition. Pics to follow.
SOLD
« Last Edit: November 07, 2012, 10:51:37 am by rallydiesel »
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #1November 03, 2012, 02:51:42 pm
bbob203
  • 1789
Re: FS AAZ K14 turbo
« Reply #1 on: November 03, 2012, 02:51:42 pm »
do you have the manifolds for it to? w/o egr.
« Last Edit: November 03, 2012, 03:03:08 pm by bbob203 »
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #2November 03, 2012, 05:04:51 pm
rallydiesel
  • 1880
« Reply #2 on: November 03, 2012, 05:04:51 pm »
It uses the same trapezoidal manifold as the 1.6td. And no, I don't have one.
Reply #3November 03, 2012, 07:51:31 pm
rallydiesel
  • 1880
« Reply #3 on: November 03, 2012, 07:51:31 pm »
Reply #4November 04, 2012, 02:15:14 am
Syncroincity
  • 727
« Reply #4 on: November 04, 2012, 02:15:14 am »
I have some spare trapezoid manis.
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
Reply #5November 05, 2012, 05:25:07 pm
81 vw pu
« Reply #5 on: November 05, 2012, 05:25:07 pm »
What changes would I have to make to replace my k24 with the aaz k14 on a 1.6 in a mk1???
Manifold to turbo-- same
Exhaust outlet-- same
Air inlet--?
Air outlet?
Oil lines, supply and return--?
Reply #6November 05, 2012, 06:14:03 pm
« Reply #6 on: November 05, 2012, 06:14:03 pm »
The air inlet to the compressor is smaller.  You can bush it with a piece of hose and just clamp over both pieces.  The air out is the same size although the elbow to intake might need to be changed.  I've always run to an intercooler so the different elbow designs haven't entered into the picture.  Exhaust in and out are the same.  Oil supply is the same.  Oil return is different, but would be bolt-on from a 1.6ECOdiesel.
Reply #7November 05, 2012, 06:46:37 pm
81 vw pu
« Reply #7 on: November 05, 2012, 06:46:37 pm »
Thanks libbydiesel, I'm intercooled as well so no problem on air outlet as long as its the same size.
I'm running a stock 1.6 td oil return that I cut the leaking flex out of and added a piece of silicon hose.
Was wondering what type of connection is under the duct tape on oil return in the pic? (threaded nipple or barb)
Reply #8November 06, 2012, 06:10:48 pm
« Reply #8 on: November 06, 2012, 06:10:48 pm »
Oil return should be a flange. 2 bolts hold it on.
Reply #9November 06, 2012, 06:19:09 pm
« Reply #9 on: November 06, 2012, 06:19:09 pm »
K14 doesn't have an oil return flange, it has a tube that threads into the turbo and then the oil return line threads onto the tube.
Reply #10November 06, 2012, 07:14:37 pm
81 vw pu
« Reply #10 on: November 06, 2012, 07:14:37 pm »
$225 plus shipping.
Pm Sent last night.
Reply #11November 06, 2012, 07:19:31 pm
rallydiesel
  • 1880
« Reply #11 on: November 06, 2012, 07:19:31 pm »
Here's a pic of the oil return. Feed is also a threaded fitting but without the extension tube.
