Author Topic: Mk2 to mk1 diesel swap  (Read 4101 times)
October 05, 2012, 12:45:09 pm
srgtlord
  • 797
« on: October 05, 2012, 12:45:09 pm »
          So I am confronted with only a few options to get get behind a diesel again. One idea is to swap my diesel engine from my rusted out mk2 into the mk1 cabriolet I have. As it sits it has an auto tranny, power steering, working airconditioning, yada yada yada. The MK2 had manual steering and no airconditioning and obviously a 5 speed.  Now the question is... What would I have to aquire/ do to make the diesel engine fit besides engine mounts? I would like to keep the power steering and A/C  if possible in the cabriolet.
« Last Edit: October 05, 2012, 12:47:37 pm by srgtlord »
Reply #1October 05, 2012, 01:30:01 pm
Re: Mk2 to mk1 diesel swap
« Reply #1 on: October 05, 2012, 01:30:01 pm »
Power steering will be cake. A/c will have to diesel specific because of IP
Reply #2October 05, 2012, 05:50:08 pm
srgtlord
  • 797
« Reply #2 on: October 05, 2012, 05:50:08 pm »
What about the shifter linkage and pedal assembly?
Reply #3October 05, 2012, 08:23:33 pm
« Reply #3 on: October 05, 2012, 08:23:33 pm »
You'd need the full on mk1 standard setup. Shifter, linkages, the piece on the steering rack..
Clutch pedal i think is also mk1 specific, but I am not certain.
Reply #4October 06, 2012, 08:59:30 am
srgtlord
  • 797
« Reply #4 on: October 06, 2012, 08:59:30 am »
Darn I was afraid of that. I think a swap to an mk3 would be easier at this point....
Reply #5October 06, 2012, 11:02:47 am
« Reply #5 on: October 06, 2012, 11:02:47 am »
you can pull a mk2 engine, change 1 (or 2) engine mounts depending on year, and bolt it right in a mk3..
mk2 and mk3 are WAY closer than mk2 and mk1..
Reply #6October 08, 2012, 11:33:38 am
srgtlord
  • 797
« Reply #6 on: October 08, 2012, 11:33:38 am »
I think ill just finish fixing up the cabby  and put a for-sale sign on it. Then ill go find another MK2 or MK3.
« Last Edit: October 08, 2012, 11:35:20 am by srgtlord »
