Author Topic: Master Cylinder Upgrade  (Read 4497 times)
October 01, 2012, 02:53:05 pm
« on: October 01, 2012, 02:53:05 pm »
I need to replace my master cylinder.
I am running disc brakes (and the entire rear axle) off a 1991 Jetta GLI in my 1985 Golf. I intend to stick with the stock 4 way setup and "shotgun shell" proportioning valves.
I know there is some difference between the brake setup between these years, but I'm not sure what it is.
Should I use a master cylinder for the 1991+ cars (without ABS)? They are about the same price as the earlier MK2 cylinders, and I can't figure out what the difference is.
Thanks.
Reply #1October 01, 2012, 02:59:40 pm
vwroadkill
  • 137
Re: Master Cylinder Upgrade
« Reply #1 on: October 01, 2012, 02:59:40 pm »
they are the same.. I will look again tonight... but I believe they are the same master cylinders. as they are MK2's.
new owner of an 81 caddy diesel yipeeeee..vw gti vr6 and well most of gm's trucks
Reply #2October 01, 2012, 03:06:59 pm
« Reply #2 on: October 01, 2012, 03:06:59 pm »
There is a different part number for 91+ which is the same for the mk3 (without ABS).
Reply #3October 01, 2012, 03:10:06 pm
vwroadkill
  • 137
« Reply #3 on: October 01, 2012, 03:10:06 pm »
crap forgot.. same as the corrado.. but I believe they will work.
ok I went and checked.. from what I saw at the shop... the mastercylinders should be interchangeable.. as long as they where both disc.  the bore of the mastercylinder has the same dimensions
that being I checked a G-60 corrado and a GTI. both being 90 models...
hope this helps..
Dan
« Last Edit: October 01, 2012, 06:33:19 pm by vwroadkill »
Reply #4October 02, 2012, 11:35:46 am
« Reply #4 on: October 02, 2012, 11:35:46 am »
Thanks.
mk3 uses a 22mm master, and its a bolt on upgrade..
you cant use an ABS m/c even if you were DETERMINED to make it work.. they are just far too different..
Reply #5October 02, 2012, 04:15:39 pm
« Reply #5 on: October 02, 2012, 04:15:39 pm »
Yup put a 98 TDI master on my 90 German when it died.. Didnt know if it would work at the time but it did.
Reply #6October 02, 2012, 05:07:00 pm
bbob203
  • 1789
« Reply #6 on: October 02, 2012, 05:07:00 pm »
what size mc is a mk2?
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #7October 02, 2012, 07:37:30 pm
« Reply #7 on: October 02, 2012, 07:37:30 pm »
idk, 19-21mm i believe, depending on brake combo..
