Author Topic: AAZ 'split-ring' IP  (Read 3618 times)
September 26, 2012, 05:21:58 pm
Big Daddy Roth
  • 298
AAZ 'split-ring' IP
« on: September 26, 2012, 05:21:58 pm »
Are they any good? or are they one step up from an non-LDA eco-diesel pump?
1993 TD B3 Sedan
1992 G60 Syncro B3 Sedan
Reply #1September 26, 2012, 07:06:22 pm
Re: AAZ 'split-ring' IP
« Reply #1 on: September 26, 2012, 07:06:22 pm »
What do you mean by split ring? In stock form, a 1.6TD pump puts out the most fuel
Reply #2September 26, 2012, 07:40:14 pm
Big Daddy Roth
  • 298
« Reply #2 on: September 26, 2012, 07:40:14 pm »
The later AAZ pump that uses the TDI lock pin for timing.
1993 TD B3 Sedan
Reply #3September 26, 2012, 07:41:53 pm
« Reply #3 on: September 26, 2012, 07:41:53 pm »
It's the same as the early ones, just uses a different main body.
