Author Topic: I need a 210mm flywheel WITH TDC mark!  (Read 7368 times)
September 23, 2012, 10:12:30 pm
erice1984
  • 263
« on: September 23, 2012, 10:12:30 pm »
Anyone know where one could be?
I have one from a digifant gasser and no TDC.  I have timed this engine ~10-15 times and only had 1 time I considered acceptable.  Bottom line is, this is wasting my time and would like to get a hold of a 210mm flywheel with a factory TDC mark.
Thanks
-Eric
EDIT: This MUST fit a 020 transmission.
« Last Edit: September 29, 2012, 02:43:10 pm by erice1984 »
1980 Rabbit 1.9TD
Reply #1September 24, 2012, 05:08:08 am
Re: I need a 210mm flywheel WITH TDC mark!
« Reply #1 on: September 24, 2012, 05:08:08 am »
AAZ from canada
Reply #2September 24, 2012, 05:13:32 am
« Reply #2 on: September 24, 2012, 05:13:32 am »
tdc on a mk2 210mm flywheel is beside a bolt.. its just a dimple... not a cut out.....
Reply #3September 24, 2012, 11:49:48 am
erice1984
  • 263
« Reply #3 on: September 24, 2012, 11:49:48 am »
AAZ from canada
AAZ from CA had a 210mm setup?  I thought it was 228mm..
Ah ha! I see it now, the Passat with AAZ had 228mm the Jetta with AAZ had 210mm
« Last Edit: September 24, 2012, 11:51:27 am by erice1984 »
1980 Rabbit 1.9TD
Reply #4September 24, 2012, 12:08:09 pm
erice1984
  • 263
« Reply #4 on: September 24, 2012, 12:08:09 pm »
027105271nx - Sachs P/N: W0133-1599035 At www.autohausaz.com I can see the TDC mark in the picture, nearest the bolt hole.
VERIFIED the above part number does have the TDC mark on it.
027105271p shows up as fitting cabrio etc...  (gas engines, I assume this does not have TDC mark.)
Thanks for the lead theman53
« Last Edit: September 27, 2012, 09:45:48 am by erice1984 »
1980 Rabbit 1.9TD
Reply #5September 24, 2012, 01:01:41 pm
« Reply #5 on: September 24, 2012, 01:01:41 pm »
why not??? timming belt... gotta know tdc on them too....
what i find is someone screws up and forces it on when doing clutch job... aka ignored dowles and got it in the other 2/3 ways it can bolt on incorrectly.. but all vw that it fits has tdc for timming belt...
Reply #6September 24, 2012, 06:13:45 pm
« Reply #6 on: September 24, 2012, 06:13:45 pm »
I have a couple aaz in the shed. I will see if I have a flywheel I can part with.
Reply #7September 24, 2012, 06:15:01 pm
erice1984
  • 263
« Reply #7 on: September 24, 2012, 06:15:01 pm »
Don't worry about it.  I ordered a new one from autohausaz.  I appreciate the offer though.
1980 Rabbit 1.9TD
Reply #8September 25, 2012, 10:20:07 am
« Reply #8 on: September 25, 2012, 10:20:07 am »
the mk2 gassers with CIS had a TDC mark, and usually degree marks as well..
i use early mk2 CIS flywheels.. a STOCK gasser flywheel is like a lightened flywheel on a diesel.
Lucas, if you have an 020 flywheel off an AAZ, would you snap some pics for me, or simply weigh it?
Reply #9September 25, 2012, 02:27:05 pm
« Reply #9 on: September 25, 2012, 02:27:05 pm »
12.8lbs
I am 99% sure on that, I looked for the flywheels but I am loosing stuff until the shed is done. I couldn't find it, but I remember weighing mine and I pretty sure it weighed 12.8lbs. If it wasn't 12.8lbs it is 12.6 for sure one of the 2 is correct.
Reply #10September 25, 2012, 06:54:31 pm
« Reply #10 on: September 25, 2012, 06:54:31 pm »
My 210mm 020 Gas flywheel was easily twice as light as the 228mm 02A TDI flywheel I took off the engine lol. SUPER UPGRADE !
Reply #11September 26, 2012, 11:51:07 am
« Reply #11 on: September 26, 2012, 11:51:07 am »
12.8lbs
ok, cause the 16v flywheel i just installed on my diesel, was ~13#s
02A flywheels ARE easily TWICE as much..
Reply #12September 29, 2012, 12:20:59 pm
« Reply #12 on: September 29, 2012, 12:20:59 pm »
Can you do me a favor and when you get this measure it. I and a friend of mine want to know what the actual face to face measurement is on an unmolested flywheel. That way we could know if there is a problem when resurfacing. Thanks Lucas><>
Reply #13September 29, 2012, 02:39:07 pm
erice1984
  • 263
« Reply #13 on: September 29, 2012, 02:39:07 pm »
Will do.
1980 Rabbit 1.9TD
Reply #14September 29, 2012, 02:42:20 pm
erice1984
  • 263
« Reply #14 on: September 29, 2012, 02:42:20 pm »
This flywheel, I forgot to check which trans version it is for.  It is not going to work in a 020.  Damnit.
EDIT: The flywheel is in fact meant for 020, just a later version, the 16v.  Not sure if it will work under the 8v transmission I have.
« Last Edit: October 21, 2012, 01:18:26 pm by erice1984 »
1980 Rabbit 1.9TD
