Author Topic: k14 turbo on a TDI??  (Read 15910 times)
September 21, 2012, 08:13:28 am
xxkoadyxx
  • 179
« on: September 21, 2012, 08:13:28 am »
Hello! I was wondering if I could put my k14 turbo from my TD onto my tdi? To save time in building a new downpipe, and also the k14 has a larger intake opening. I don't see the problem with it. But what do you guys think? I won't be running EGR, ill be blocking it off.
93 vw Golf 1.9TD soon to be stage 3 malone TDi (project)
2003 VW 1.8T Passat (daily)
Reply #1September 21, 2012, 08:48:25 am
Re: k14 turbo on a TDI??
« Reply #1 on: September 21, 2012, 08:48:25 am »
yeah it will work as well on the tdi as it did on the car you got it from
Reply #2September 21, 2012, 04:06:19 pm
« Reply #2 on: September 21, 2012, 04:06:19 pm »
Is this an electronic TDI still? or mechanical? It will need a tune to notice any difference in power I am thinking.
A k14 was recommended to me for my M-TDI build, so apparently it is a good idea. ;) They guy that told me has used them on a few M-TDI swaps.. loves them.
Reply #3September 21, 2012, 05:22:47 pm
« Reply #3 on: September 21, 2012, 05:22:47 pm »
I would always say to go with something bigger but everyone has their own price and driving preference
Reply #4September 21, 2012, 06:47:31 pm
xxkoadyxx
  • 179
« Reply #4 on: September 21, 2012, 06:47:31 pm »
itll still be a regular TDi, i have a stage 3 malone tune also. i just  dont see the point in changing and building a new down pipe if itll work the same?
Reply #5September 21, 2012, 07:12:09 pm
« Reply #5 on: September 21, 2012, 07:12:09 pm »
What year engine is this?
Reply #6September 22, 2012, 02:39:21 am
xxkoadyxx
  • 179
« Reply #6 on: September 22, 2012, 02:39:21 am »
Its a 96/97 I think, can't remember
Reply #7September 22, 2012, 09:19:38 am
GTiTDi
  • 153
    Schnell Snail TDI performance
    • My 91 GTI --> TDI swap thread
« Reply #7 on: September 22, 2012, 09:19:38 am »
Seems like it would be too small to be worthwhile...here is a thread I found about it http://forums.tdiclub.com/showthread.php?t=329905
I had enough of my "heat pump" so here is what I did...http://forums.tdiclub.com/showthread.php?t=360678
91 GTI/ AHU spec'd 1Z power, GT2052W w custom adapter (available through me, PM me for details),TDTUNING software, PP764 nozzles, Massive spearco FMIC, PD intake, Koni reds
97 B4VGLX AHU, RC3, 357's, PP'd head, Shine springs and Koni yellows
Reply #8September 22, 2012, 09:54:41 am
« Reply #8 on: September 22, 2012, 09:54:41 am »
They are a step up from the K03.  There's a little more lag but noticeably more power for similar boost.  The increase in power becomes progressively more noticeable over 10 psi of boost.  The K14 is also a more robust unit with a thicker shaft and better bearing support.  If going with a K14, be sure to get one from the AAZ and not from a 1.6ECO motor as the AAZ version has a larger compressor wheel.  You can tell the difference externally by the fact that the AAZ version has 4 bolts holding the center section to the turbine housing instead of 6 with the 1.6ECO version.
Reply #9September 22, 2012, 10:56:07 am
« Reply #9 on: September 22, 2012, 10:56:07 am »
Gti tdi great to see people trying different turbos!
Reply #10September 22, 2012, 11:42:15 am
GTiTDi
  • 153
« Reply #10 on: September 22, 2012, 11:42:15 am »
It works very well too. I will post up dyno slips once it is dyno'd, but estimates are around 180 hp/300 ft lbs since my Sachs VR6 clutch doesn't hold well when you get into it on the highway.
Reply #11September 22, 2012, 12:35:59 pm
« Reply #11 on: September 22, 2012, 12:35:59 pm »
I'm not a fan of vnt turbos simply because wg turbos are more simple and still perform very well.  So it's cool to see someone using one
Reply #12September 22, 2012, 05:09:55 pm
GTiTDi
  • 153
« Reply #12 on: September 22, 2012, 05:09:55 pm »
I share the same sentiments. I have never had to free up a waste gate, unlike every mk4 ALH tdi that I have come across...
Reply #13September 22, 2012, 08:40:16 pm
« Reply #13 on: September 22, 2012, 08:40:16 pm »
I've had to free up several wastegates.
To free stuck vanes on a VNT all you have to do is take it on a cruise on the freeway or up an extended grade.  My mechanical control is smooth as silk after a couple years of use.  I was working on it today and checked the vanes and they have absolutely no resistance to them.
Reply #14September 22, 2012, 08:52:14 pm
GTiTDi
  • 153
« Reply #14 on: September 22, 2012, 08:52:14 pm »
Take it on a cruise. Riiiiiiiiiiight. Actually no sorry the ones I have dealt with were beyond an Italian tune up. Sea foam poured down the egr passage into the hot side works a treat though! Actually I love the GT2052W because of the simplicity of my system. The tune I am running eliminates the N75 and the MAF, I am running a home made MBC.
