Author Topic: Which injection pipes for a franken 1.6/1.9 engine?  (Read 5761 times)
September 09, 2012, 10:08:03 am
TurboJ
  • 661
« on: September 09, 2012, 10:08:03 am »
So I have and AAZ head and AAZ injectors on my 1.6 TD block.
The AAZ injectros have a noticeably longer body than 1.6 injectors, so the stock
injection pipes don't fit very well.
What injection pipes have you used with 1.9 injectors and a 1.6 block?
At least T2 1.6 TD and T4 1.9 TD pipe sets are available for me.
I don't think AAZ pipes will work either as the pump sits at a different angle on the block.
Jetta II 1.6 TD 'Project 200'
Reply #1September 09, 2012, 10:37:30 am
Re: Which injection pipes for a franken 1.6/1.9 engine?
« Reply #1 on: September 09, 2012, 10:37:30 am »
I would think u must use 1.9 lines, and that is what I've read on here in the past
Reply #2September 09, 2012, 11:09:42 am
TurboJ
  • 661
« Reply #2 on: September 09, 2012, 11:09:42 am »
Would T4 1.9 TD lines work?
Golf III / Passat ones aren't available at my supplier.
Reply #3September 09, 2012, 11:20:02 am
« Reply #3 on: September 09, 2012, 11:20:02 am »
I wouldn't know haha, I do have 2 sets of aaz lines tho, I'd send them to you for the cost of shipping but I'm not sure if they are the dual stage lines or not
Reply #4September 09, 2012, 12:56:19 pm
« Reply #4 on: September 09, 2012, 12:56:19 pm »
There aren't any lines that will fit that combination without bending them because the taller injectors were never used with the shorter block.  If you use 1.6 injectors you could use 1.6 lines.  1.9 lines won't fit because the 1.9 block is taller.
Reply #5September 09, 2012, 02:31:04 pm
TurboJ
  • 661
« Reply #5 on: September 09, 2012, 02:31:04 pm »
Well, which lines would require the least amount of bending?
Reply #6September 09, 2012, 02:39:49 pm
« Reply #6 on: September 09, 2012, 02:39:49 pm »
Probably ones from a Mercedes 300 series 3.0 L 5-cylinder.
Reply #7September 09, 2012, 03:53:27 pm
rallydiesel
  • 1880
« Reply #7 on: September 09, 2012, 03:53:27 pm »
Isn't the 1.9 pump body also a bit longer than the 1.6?
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #8September 09, 2012, 06:18:38 pm
« Reply #8 on: September 09, 2012, 06:18:38 pm »
The 1.9 has an extended nose, but that doesn't come into play because it is on the other end of the injection pump bracket.
Reply #9September 09, 2012, 06:22:46 pm
Powered by Spearco
  • 1203
« Reply #9 on: September 09, 2012, 06:22:46 pm »
I'm using the 1.6 TD lines on 1.9 injectors with the long delivery valves.
Only slight bending was needed to make them work and can still be used on 1.6 injectors.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #10September 10, 2012, 03:09:35 am
TurboJ
  • 661
« Reply #10 on: September 10, 2012, 03:09:35 am »
I have an Iveco 2.5 TD pump which is a LOT longer than a 1.6 pump :)
I guess I'll have to do some bending no matter what, I just hope that won't affect flow rates of the individual pipes...
Of course I could get a set of second hand pipes first and then use them as a template. Every part on this engine needs
to be new you know  ;)
Reply #11September 10, 2012, 03:10:51 am
TurboJ
  • 661
« Reply #11 on: September 10, 2012, 03:10:51 am »
Have you tried them? This is an interesting idea. I wonder if the pipes have the same diameter.
Even very small diameter differences can cause surprising effects...
Reply #12September 10, 2012, 11:19:28 am
« Reply #12 on: September 10, 2012, 11:19:28 am »
the PUMP is in the same spot as the 1.6, is it not?
Reply #13September 10, 2012, 12:11:19 pm
Jetmugg
  • 530
« Reply #13 on: September 10, 2012, 12:11:19 pm »
Mercedes uses inline pumps, it would be a miracle if those lines would work on a VW 1.6/1.9 setup.
Reply #14September 10, 2012, 12:49:02 pm
« Reply #14 on: September 10, 2012, 12:49:02 pm »
i dont see 300D lines working easily...
the merc uses an inline Bosch A pump..
