Author Topic: Questions on front struts for a 1992 cabriolet?  (Read 3588 times)
July 28, 2012, 05:26:26 am
srgtlord
  • 797
« on: July 28, 2012, 05:26:26 am »
What springs would fit a 1992 cabriolet? I know the cabby is suppose to be almost exactly a copy of the gti, but will any year rabbit front struts fit?
Reply #1July 28, 2012, 06:22:32 am
Re: Questions on front struts for a 1992 cabriolet?
« Reply #1 on: July 28, 2012, 06:22:32 am »
yes any mk1 75-84 bunny/jetta/caddy are same... but if jut doing inserts you need  to see if you have internal or external nut holding the insert in.. sadly the strut housings can be swapped over the years.. thinking  oriinal 92 may not be able to change inserts.. so need to look at/for the nut...
the koni yellow adjustables are impressing me on my kubvan... but almost 200 each... i got my pair used for far less..
old boge turbos if you can find a set are nice... but sachs took them over and well suck now...
bilstine... their warentee service sucked... but ride nice till that point..
Reply #2July 28, 2012, 06:50:58 am
srgtlord
  • 797
« Reply #2 on: July 28, 2012, 06:50:58 am »
It looks like one front strut was replaced, so I am clueless about how these 2 compare, whether the inserts are replaceable or not.
Reply #3July 28, 2012, 02:01:14 pm
« Reply #3 on: July 28, 2012, 02:01:14 pm »
where the shock shaft slides into the strut housing... big nut... either it goes over the housing... into the housing.. or looks like a welded into place nut.. take pics.. i can help..
