Author Topic: 1Z & AAZ same valve cover gasket?  (Read 4092 times)
July 08, 2012, 07:06:03 pm
wolf_walker
  • 1205
« on: July 08, 2012, 07:06:03 pm »
I apparently ordered one for an AHU and they are obviously not the same.
Near as I can tell the AAZ is the same as the 1Z, like this one..
http://www.oreillyauto.com/site/c/detail/BA00/0361658.oap?ck=Search_028103483h_-1_3693&keyword=028103483h
I'm trying to combine some stuff on an amazon order and get it all together if I can.
help?
Mentat Text Two
Reply #1July 08, 2012, 07:09:10 pm
Re: 1Z & AAZ same valve cover gasket?
« Reply #1 on: July 08, 2012, 07:09:10 pm »
AHU and 1Z are the same AFAIK. Are you sure you didn't order one for the ALH?
Reply #2July 08, 2012, 07:18:49 pm
wolf_walker
  • 1205
« Reply #2 on: July 08, 2012, 07:18:49 pm »
Damned if I know, I think IMC's catalog screwed me up, or it was really late.  It has the flat side and the other long side of the gasket is wavy, not straight.  It's a TDI something I'm sure.
Mentat Text Two
Reply #3July 08, 2012, 07:21:40 pm
ToddA1
  • 434
« Reply #3 on: July 08, 2012, 07:21:40 pm »
The one you linked is for a standard 8v IDI.  My 1z is as you described.  The valve cover is held on by 3 nuts.
-Todd
Reply #4July 08, 2012, 07:30:04 pm
« Reply #4 on: July 08, 2012, 07:30:04 pm »
ALSO, the 1Z and AHU valve cover is not straight at the front.
This is a the AHU gasket;
AAZ gasket;
Normal 1.6 IDI gasket;
Reply #5July 08, 2012, 07:41:22 pm
wolf_walker
  • 1205
Re: Re: 1Z & AAZ same valve cover gasket?
« Reply #5 on: July 08, 2012, 07:41:22 pm »
Yep, got an AHU gasket.
Sent from my PC36100 using Tapatalk 2
Mentat Text Two
Reply #6July 08, 2012, 08:19:17 pm
« Reply #6 on: July 08, 2012, 08:19:17 pm »
VW in their infinate wisdom doesn't sell a valve cover only gasket for the ALH. You have to spend over 120.00 for the new valve cover with a gasket. I hope he didn't do that.
Reply #7July 08, 2012, 08:25:59 pm
wolf_walker
  • 1205
« Reply #7 on: July 08, 2012, 08:25:59 pm »
No, got just a gasket with some gromets (which do look like my AAZ's).  Looks like an AHU gasket.
I'm pretty sure this one I linked is an AAZ part.
Even though it lists 1Z and AHU.
Also this one..
http://www.napaonline.com/Catalog/CatalogItemDetail.aspx?R=ATM028103483F_0257263965
I see that the original one is sort of made into the valve cover, the replacement seems to be thicker to fill the channel in the valve cover, I assume you dig and scrape the original one out and replace it with this one.
Mentat Text Two
Reply #8July 09, 2012, 07:45:34 am
« Reply #8 on: July 09, 2012, 07:45:34 am »
Right, I forgot about that
