S-PAutomotive.com
Author Topic: 1.9aaz moded to TDI in a Jeep.  (Read 69333 times)
Reply #90April 28, 2013, 11:43:27 pm
  • 7834
Re: 1.9aaz moded to TDI in a Jeep.
« Reply #90 on: April 28, 2013, 11:43:27 pm »
I need the distance measured from the block to bellhousing mating surface to the flywheel clutch surface on a 4.0L Jeep engine with an AX-15 or NV3550 trans/flywheel in it.
If anyone has it that would be great. I have posted on about every forum I can think of with nothing back yet.
Reply #91May 04, 2013, 10:22:27 am
  • 7834
« Reply #91 on: May 04, 2013, 10:22:27 am »
I got this from a guy online. I am going with it and if needed I will make adjustments. For me and all those who want to know
The overall thickness of the adapter is 1-9/16 with a cutout for the starter. The thickness at the cutout is 5/16. The flywheel spacer appears to be ~1-3/8 thick. I couldn't really get into the bellhousing to get a good measurement. When I pull it all back out I'll check with ya and see if you still need the measurement. I'm not sure when that will be as I'm waiting on some parts again.
Reply #92May 07, 2013, 09:12:55 am
  • 7834
« Reply #92 on: May 07, 2013, 09:12:55 am »
With the gas to diesel conversions you guys are doing I have a question. What do you do with the fuel pump that is in the tank? It looks to be part of the sending unit. Also, how do you route the return? I have 0 experience with newer jeeps and want some info on the best way to do it. LMK
Reply #93May 07, 2013, 02:21:29 pm
« Reply #93 on: May 07, 2013, 02:21:29 pm »
you should be able to either fit a regulator, and turn the pressure down, or remove the pump, and fab up a new pickup tube to go in its place..
use the gasser fuel return line as your return line from the pump..
Reply #94May 07, 2013, 06:45:52 pm
  • 7834
« Reply #94 on: May 07, 2013, 06:45:52 pm »
Cool, that is what I will try. Using a regulator and turning it down maybe just what I want. Constant pressure feed @ 7 psi or so should do the TDI just fine.
Reply #95May 08, 2013, 12:30:49 am
« Reply #95 on: May 08, 2013, 12:30:49 am »
FWIW, you might want to use a regulator with a return built into it as well.. idk if the fuel pump will like being chiked down to 7 psi..
Reply #96June 04, 2013, 10:10:21 am
  • 7834
« Reply #96 on: June 04, 2013, 10:10:21 am »
Thinking on this more, what about the gas cap? some are vented some are not. What do I do about that?
Reply #97June 04, 2013, 06:18:28 pm
  • Administrator
« Reply #97 on: June 04, 2013, 06:18:28 pm »
Diesels generally are always vented - diesel doesn't evaporate like gas does.
Reply #98June 09, 2013, 10:00:57 pm
  • 7834
« Reply #98 on: June 09, 2013, 10:00:57 pm »
Needed this for the revisions.
Reply #99June 11, 2013, 11:10:17 am
  • 7834
« Reply #99 on: June 11, 2013, 11:10:17 am »
http://www.factorychryslerparts.com/products/BRACKET-Transmission-Mount-ER0--Trans-Support/4465077/52058546AB.html
This site just tells me that the cross members are the same in the ax 5 and Ax 15 and NV3550. If I forget or someone searches this now we know.
« Last Edit: June 11, 2013, 09:13:00 pm by theman53 »
Reply #100June 12, 2013, 04:05:10 pm
  • 7834
« Reply #100 on: June 12, 2013, 04:05:10 pm »
One huge step towards getting the trans to work in the Jeep TJ.   ;D
« Last Edit: July 20, 2013, 08:26:13 pm by theman53 »
Reply #101June 15, 2013, 05:05:45 pm
« Reply #101 on: June 15, 2013, 05:05:45 pm »
will look perty in ohio patena.. :D
Reply #102July 04, 2013, 10:21:27 pm
  • 7834
« Reply #102 on: July 04, 2013, 10:21:27 pm »
crank spacer bolted on and the Jeep flywheel bolted onto it as well. Fit is fine, but my 40mm crank bolts are 2.4mm too long. I have to cut or grind them down so they don't stick through the crank. If I am lucky I will find the exact space for the bell housing tomorrow.
Reply #103July 07, 2013, 02:25:28 pm
  • 7834
« Reply #103 on: July 07, 2013, 02:25:28 pm »
This is the template. I have to drill the second set of holes but it is measured and done.
Reply #104July 20, 2013, 08:25:45 pm
  • 7834
« Reply #104 on: July 20, 2013, 08:25:45 pm »
