Author Topic: just picked up a tdi swap  (Read 7865 times)
June 12, 2012, 02:04:38 pm
xxkoadyxx
  • 179
« on: June 12, 2012, 02:04:38 pm »
hello, i just picked up a tdi swap with a stage 3 ecu i was told. Now my question is, what should i do first to this engine? my car is a 1.9TD with ACT clutch. blah blah blah, but im looking for more fuel milage/power. I was thinking of running my stock 020 tranny with the ACT untill i get the hydro setup complete. i also plan on "rebuildin the outside of the engine. what are some main maintanice things i should take care of? also what would be a good/cheap upgrade for turbo, intake, injectors?
I have many more questions, but ill start there :P
aslo if anyone has a tdi Drive by wire they would sell, LMK! :)
cheers guys!
93 vw Golf 1.9TD soon to be stage 3 malone TDi (project)
2003 VW 1.8T Passat (daily)
Reply #1June 12, 2012, 06:37:10 pm
Re: just picked up a tdi swap
« Reply #1 on: June 12, 2012, 06:37:10 pm »
oh boy. lol I hope you did a lot of reading before diving in to this head first.. Which TDI is it? There is more than one ;).
This is an awesome the swap you are undertaking, at-least you don't have to worry about motor mounts.
Reply #2June 13, 2012, 03:37:47 pm
xxkoadyxx
  • 179
« Reply #2 on: June 13, 2012, 03:37:47 pm »
Its a mk3 AHU TDi, and I'm getting a stage 3 mahone chipped ecu. I need .216 or .205 injectors. Also I mainly need the drive by wire behind the gas pedal.
Reply #3June 15, 2012, 09:45:59 am
Henk
  • 111
« Reply #3 on: June 15, 2012, 09:45:59 am »
Didn't know the did chips for the AHU, do not buy one from an ALH or other engine, it will not work.
As for the DBW you just need the throttle position sensor right? and possibly the wiring?
I've got everything here in my donor car but won't be using it as i'm going for a mechanical pump. seems i'm a bit far away though!
Mid Engine
Berg Cup
M-TDi
Caddy!
Reply #4June 15, 2012, 11:45:14 am
xxkoadyxx
  • 179
« Reply #4 on: June 15, 2012, 11:45:14 am »
how much would you want for the DBW? were you located?
Reply #5June 15, 2012, 12:14:49 pm
Henk
  • 111
« Reply #5 on: June 15, 2012, 12:14:49 pm »
like £10. just across the pond from you...  ;) http://goo.gl/maps/vF7u
Mid Engine
Berg Cup
M-TDi
Caddy!
Reply #6June 15, 2012, 08:20:10 pm
xxkoadyxx
  • 179
« Reply #6 on: June 15, 2012, 08:20:10 pm »
What's that? Euros? Can you see how much shipping would be?
Reply #7June 26, 2012, 02:24:16 pm
GTiTDi
  • 153
    Schnell Snail TDI performance
    • My 91 GTI --> TDI swap thread
« Reply #7 on: June 26, 2012, 02:24:16 pm »
LOL!! You need a course in international currency!
91 GTI/ AHU spec'd 1Z power, GT2052W w custom adapter (available through me, PM me for details),TDTUNING software, PP764 nozzles, Massive spearco FMIC, PD intake, Koni reds
97 B4VGLX AHU, RC3, 357's, PP'd head, Shine springs and Koni yellows
Reply #8June 26, 2012, 03:20:35 pm
rallydiesel
  • 1880
« Reply #8 on: June 26, 2012, 03:20:35 pm »
There's really no cheap turbo options unless you have a welder and can build-up a compound set-up using junkyard turbos. New vnt's that will increase your performance are generally ~$1500. Plus you will require a re-tune afterwards. Unless you build your own mtdi pump.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #9June 27, 2012, 12:26:21 pm
« Reply #9 on: June 27, 2012, 12:26:21 pm »
lol.. my VNT20, with manifold was ALOT cheaper than that..
only time a VNT is that expensive, is when you buy new..
Reply #10June 27, 2012, 01:26:05 pm
« Reply #10 on: June 27, 2012, 01:26:05 pm »
Or your don't posses the skills necessary to fabricate.. Like most.
Reply #11June 28, 2012, 09:14:29 am
« Reply #11 on: June 28, 2012, 09:14:29 am »
good point.. it would have gotten REAL EXPENSIVE if i would have had someone build my intake manifold, and have someone modify the turbo header to make it fit as well..
ive got a good 20-30 hours just in making the stuff fit the car!
Reply #12June 28, 2012, 02:14:30 pm
rallydiesel
  • 1880
« Reply #12 on: June 28, 2012, 02:14:30 pm »
I said new, if you actually read my post.  ::)
Reply #13November 01, 2012, 12:01:56 pm
xxkoadyxx
  • 179
« Reply #13 on: November 01, 2012, 12:01:56 pm »
alright guys, i got the old pedal out... When i went to find the mounting spot for the DBW actuator
i couldnt find anywere... am i just blind? is that the right one? i was told it was.. picture of pedal area.
red slash is were the pedal pin slide thru and the yellow  is where the old cable went through
