Author Topic: GT2056V on a 1.6TD...  (Read 51218 times)
Reply #90June 13, 2012, 02:06:51 pm
Re: GT2056V on a 1.6TD...
« Reply #90 on: June 13, 2012, 02:06:51 pm »
ive got 2 male heim joints, 2 female heim joints, and 2 ball-n-socket couplers.
im gonna see what i can come up with in terms of atleast re-locating my boost can.. as well as rigging up a libby-style vane control system..
care if i use your idea Andrew? seems like thats how everyone else is controlling theirs.. and its PROVEN.
Reply #91June 13, 2012, 02:56:32 pm
« Reply #91 on: June 13, 2012, 02:56:32 pm »
I don't mind at all.
Reply #92June 13, 2012, 06:19:44 pm
camboscams
  • 324
« Reply #92 on: June 13, 2012, 06:19:44 pm »
For turning VNT actuators into boost cans, I have used micro nuts and bolts around the perimeter to make them resealable without messing with crimping and un-crimping.  I have gotten stronger springs from McMaster and then cut them to size to dial in the boost pressure.  You also have the option of adding an MBC to the boost can if you don't want to mess with the springs.  With MBCs, tho, I've run into the issue that the smaller VNTs build boost so quickly that an MBC cannot react fast enough to regulate boost and so it can spike high and then drop back to the control pressure.  Using LARGE hose and fittings can help with reaction time.
X2
Week two of non stuck vanes using Andrews system. Also noticed that I'm running decent egts which helps keep the vanes free, but nothing out of line. Nothing a downshift or a little more pedal (more boost) won't fix
I really like the picture of the water to air intercooler positioned where it is. That's the simplest setup I think I've seen.
Is that set up from Frozen boost?
81' White 1.6l Rabbit 4dr Holseted
72' Ford F-250 390cid
2014 JSW 2.0L TDI Stg 2, CP3 HPFP
Reply #93June 13, 2012, 07:25:41 pm
Rock3tman
  • 113
    prev: 60typ2, 68pickup, 79rabbitD. now: 83jettaTD
« Reply #93 on: June 13, 2012, 07:25:41 pm »
Yes on frozenboost AWIC; the only element I still need to work out is total liquid volume needed.  Auxiliary radiator located between stock radiator and core support and aux water pump is located behind the front bumper bolted to the core support.  I'm panning to use a stock radiator overflow reservoir located in the passenger side of the rain tray so that I can see fluid level, pump action, etc.
Reply #94June 14, 2012, 01:52:38 pm
« Reply #94 on: June 14, 2012, 01:52:38 pm »
Here's my latest mechanical vane control concept.  The distinct advantage this version has over the previous one is that the accelerator lever can always return to idle regardless of boost pressure and there doesn't need to be the 'spring in the linkage" to allow the pump lever return spring to collapse the rod.  I would have a little concern about the fact that the accelerator would be stuck if the vanes stuck, tho.
The geometry would have to be exactly right to work correctly.
« Last Edit: June 14, 2012, 01:54:28 pm by libbydiesel »
Reply #95June 18, 2012, 11:21:27 am
« Reply #95 on: June 18, 2012, 11:21:27 am »
does anyone have the SLIGHTEST idea as to what my turbo compares to? i keep having people ask me what its equivalent to, and i cant answer, because i have no idea what its comparable to, in terms of wastegated turbos..
so, is it closer to a T3, or a T4 in terms of the amount of air it can flow efficiently?
im thinking that it should be some what better than a T3, because it is said that the VNT15 flows like a T3 on the top end..
Reply #96June 18, 2012, 11:56:01 am
MJF
  • 581
« Reply #96 on: June 18, 2012, 11:56:01 am »
2052 from 2,5 V6 is maxxed at about 180hp with 1,6.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #97June 18, 2012, 01:15:35 pm
« Reply #97 on: June 18, 2012, 01:15:35 pm »
well, i dont have a 2052, so that doesnt tell me a whole bunch..
mine started out life as a 2056v, and got bigger wheels installed.
its a Street Toys ST3-BV turbo..
Reply #98June 18, 2012, 05:45:37 pm
« Reply #98 on: June 18, 2012, 05:45:37 pm »
To compare to common turbos it should flow a little less than a 60 trim t3(300+hp) and a little bit more than what most people consider a standard t3 which is a 45 trim with a .48 at housing (225hp). Vnt15 flows about the same as the *** vw t3 which is 35 trim around 150hp and *** for efficiency.  It's in the 200-275 hp range for flow and would spool faster than all of that crap.  Physical size wise it's a gt20 so it's a t2 or t25 sized turbo.  The physical size of a turbo hardly means anything tho
To answer ur question tho its more like a medium sized t3 like a 45 or 50 trim,  it's not like a t4 really at all they are much bigger and flow 350+hp.  But yeah not like the vw t3 which is the smallest one available, more like the medium sized ones except more efficient and faster spooling especially since its a vnt
« Last Edit: June 18, 2012, 05:55:28 pm by Trev0rbr »
Reply #99June 19, 2012, 01:27:45 pm
« Reply #99 on: June 19, 2012, 01:27:45 pm »
well, andy2 suggested that i run an HX30 wastegate controller to operate the vanes.. solely based on boost pressure, not based on throttle position at all.. his thoughts were, that since the turbo is quite large already, it shouldnt be a restriction when cruising, even with the vanes all the way closed..
the HX30 WG actuator is supposed to fully open by ~23psi... and that would be IDEAL if you ask me.
is there such thing as a 2 stage wastegate?
Reply #100June 19, 2012, 01:46:43 pm
« Reply #100 on: June 19, 2012, 01:46:43 pm »
I'm not so sure about that, they are designed to be a restriction at idle so the EGR will work
Reply #101June 19, 2012, 02:04:07 pm
« Reply #101 on: June 19, 2012, 02:04:07 pm »
it probably IS a restriction at idle on the engine it was intended to be run on.
so, what was the original purpose of the vanes? was it to make the turbo spool faster, make back pressure at idle so the EGR works, both?
Reply #102June 24, 2012, 03:26:35 am
Alcaid
  • 549
« Reply #102 on: June 24, 2012, 03:26:35 am »
Both.
By setting the initial vane position to a not so closed position as they normally are run you sacrifice some of the low end spool, but get less back pressure while cruising. It spools quick compared to the stone age T3 and K24s anyway.
'10 VW Passat 1.6TDI Highline
Reply #103June 24, 2012, 12:06:34 pm
« Reply #103 on: June 24, 2012, 12:06:34 pm »
Sorry, I phrased that wrong;
I'm not so sure about that, they are designed to be able to create a restriction at idle so the EGR will work
Better?
Even more so on the ones that serve in a braking function, the HE351VE (6.7 Cummins) closes to 3.9 CM housing equivalent, while the quick spool HE351 is like a 9 cm housing
Reply #104June 25, 2012, 02:00:14 pm
« Reply #104 on: June 25, 2012, 02:00:14 pm »
ok, so, i tried driving the car in the rain yesterday.. and it didnt work. well, it did fine, but you need 1/4 mile to safely pull out on the highway..
crappy tires, incorrect alignment, and lots of torque make for a SCARY ride in the rain.. this setup EASILY has as much torque @ 7psi, as my other VNT had at 15..
