Author Topic: Replacing Factory oil cooler with a Thermo sandwich plate external.  (Read 8147 times)
May 24, 2012, 11:05:23 am
Vangruver
  • 162
Engine AAZ.
I have a thermostatically controlled sandwich plated oil cooler which I have been sitting on for the last year.
I know I have a few options when it comes to installing it. But I was hoping to use the down time the car has over the next week to consider replacing the factory oil cooler with the sandwich plate.
My curiosity is based on the coolant inlet and outlet hoses from the factory oil cooler. What do I do with those hoses when i pull off the factory cooler? Do i mock up a u-joint for the plumbing? Or can I just cap/block both ends off?
Thanks.
Reply #1May 24, 2012, 11:10:22 am
either get hoses for that engine WITHOUT accommodations for the oil cooler..
or else CAP the lines. dont loop them. if you loop them, the coolant ALWAYS bypasses the radiator..
Reply #2May 24, 2012, 11:16:58 am
Vangruver
  • 162
now on to my next question,
which engine should i look at that uses coolant hoses without the oil cooler?
Reply #3May 24, 2012, 11:33:28 am
Heat your veg tank.
Reply #4May 24, 2012, 11:48:51 am
im not the guy to answer that question unfortunately..
the 1Y might have been sans-oil cooler..
hopefully someone who KNOWS will chime in..
Reply #5May 24, 2012, 12:54:10 pm
tomsdubwerks
  • 17
Did you guys get carburetor fed petrols over there? The metal coolant pipe and hoses might work out to be of some use as they never had coolers on the non GTI petrols here in the UK.
Drives '77 Polo 1.4 16v on ITB's
            '90 Caddy Pickup 1.6 NA... Eventually 1.6TD
Reply #6May 24, 2012, 01:13:09 pm
Vitwagen
  • 68
1y was cooler less, but I'd just blank them off (I did).
GEE-BEE was selling silicone ones at one point.
Reply #7May 24, 2012, 01:48:31 pm
Any mk1 non-turbo has the right bypass hose.
Reply #8May 24, 2012, 01:51:38 pm
Vangruver
  • 162
not that i'm aware of. They seem to be more so over in the uk and europe.
Reply #9May 24, 2012, 01:53:08 pm
Vangruver
  • 162
and I may just close them off and hose clamp them shut with a cork or a stopper of somekind.
I want to do this before hit up the leavenworth cruise in mid june.
Reply #10May 24, 2012, 08:30:03 pm
  • 4549
Re: Replacing Factory oil cooler with a Thermo sandwich plate external.
« Reply #10 on: May 24, 2012, 08:30:03 pm »
I think getting a hose fitting and cap combo would be better than a cork.  You should have a hose clamp on it as it develops enough pressure after you turn off the engine to blow out anything that isn't metal in nature.  Think long haul fix not fix a day.
Reply #11May 25, 2012, 05:15:04 am
carrizog60
  • 978
« Reply #11 on: May 25, 2012, 05:15:04 am »
well,i welded shut mine.
Portugal
Reply #12May 26, 2012, 03:09:49 pm
Vitwagen
  • 68
« Reply #12 on: May 26, 2012, 03:09:49 pm »
Nope, the 1.6 is marginally too short.
Reply #13May 26, 2012, 04:14:31 pm
JamesT
  • 151
« Reply #13 on: May 26, 2012, 04:14:31 pm »
My rabbit has the weirdest bastard coolant pipes I've ever seen. It has the ports for the manifold heater, but they're just plugged, as well as the port for the expansion tank, also plugged. So the pipe, just get a little rubber cap for it and hose-clamp it on.
The mk2 n/a bypass coolant hose should work if you use the mk2 coolant flange. There's enough flex in the hose that an added 6mm in height shouldn't be a problem.
93 Golf - AAZ with some fueling
78 Rabbit - 1.5 DIESEL (finally)
[(+)===o===(+)]
 (++\==o==/++)
Reply #14May 28, 2012, 04:20:32 pm
« Reply #14 on: May 28, 2012, 04:20:32 pm »
the AAZ is 16mm taller.. not 6.
