Author Topic: more "tranny" issues for Ed  (Read 18842 times)
Reply #60June 08, 2012, 03:42:50 pm
  • 3468
    • McScrubbins Body Wash
Re: more "tranny" issues for Ed
« Reply #60 on: June 08, 2012, 03:42:50 pm »
Thanks for the tip kev
Reply #61June 08, 2012, 03:44:40 pm
  • 3468
« Reply #61 on: June 08, 2012, 03:44:40 pm »
Anyone have any tips for getting those clips on the final drive flanges? I've spent the last 90 minutes firing them across the garage and I'm finally fed up. Considering just bending them open more...
I'm using nice pliers but the openings aren't flat on the clips for what ever reason.
Reply #62June 08, 2012, 03:51:14 pm
« Reply #62 on: June 08, 2012, 03:51:14 pm »
hold the clip on the end of the stub, pushing down on them towards the groove. then with the clip positioned over the stub, stick your pliers in the opening of the clip, and slowly open it just enough to slide it over the stub shaft.. then tap it into place with a screw driver..
Reply #63June 10, 2012, 03:35:33 pm
  • 3468
« Reply #63 on: June 10, 2012, 03:35:33 pm »
Worked like a charm and she is all back together. Successssssss!!!!!!! I've changed the entire clutch, push rod, TO bearing, seals and have put the manual cable in there. Is it normal to seem much easier to depress the clutch?
Also, I can hear what sounds like the rod spinning on the plate when I push the cough in.
