Author Topic: more "tranny" issues for Ed  (Read 18810 times)
May 20, 2012, 05:55:38 pm
  • 3468
    • McScrubbins Body Wash
« on: May 20, 2012, 05:55:38 pm »
020 transmission from what i think was a 1990 1.6td.
 Went for a really long drive on a whim. 1,000km nonstop in 5th the whole time. When I turned the car back on to drive home it wouldn't shift into gears. I could rpm match all the gears and jam it into all gears but first gear and reverse. Grinds into reverse. Drives fine but its as if the clutch isn't disengaging all the way. So I pulled the cover off to take a look and everything look ed fine. I had a spare push rod bearing so I replaced it. I measured the rod which looks very worn. and its 344.4 mm  long. Everything seemed to move just fine. I peered down the hole with a bright light and the plate looks centered.
I took off the fill plug and only if I stuck m y fingers way in there could I find gear oil. Should it be filled right up to that fill hole on the side?
Reply #1May 20, 2012, 06:42:35 pm
  • 3468
Re: more "tranny" issues for Ed
« Reply #1 on: May 20, 2012, 06:42:35 pm »
Also what weight oil should I use in there? I contact remember what I put in it before but I remember it was expensive and was like 45-75w or so
Reply #2May 20, 2012, 07:00:22 pm
« Reply #2 on: May 20, 2012, 07:00:22 pm »
It maybe the finger that pushes on the pushrod. It can have a crack in it and not get full power. See brokevw's site on that. Also in the 5th housing usually you have the car jacked up on the drivers side when you access it, so you will find no fluid coming out.
75w-90 GL-4 rated, usually GL-5 rated is too slippery, Red Line and Royal Purple do well same with the new dealer stuff but all are around 20.00 per quart here.
Reply #3May 20, 2012, 07:13:56 pm
  • 3468
« Reply #3 on: May 20, 2012, 07:13:56 pm »
The finger looked totally fine. Its the original one from what I can tell. Has a bit of wear on it but the replacement one I was given was really cheap feeling and thin. And was $35...
Reply #4May 20, 2012, 07:14:40 pm
  • 3468
« Reply #4 on: May 20, 2012, 07:14:40 pm »
But could you see those symptoms from having low gear oil?
Reply #5May 20, 2012, 08:21:54 pm
  • 3468
« Reply #5 on: May 20, 2012, 08:21:54 pm »
I just purchased a new push rod. Ill add some gear oil and see if either of those do anything. I really hope this clutch isn't pooped again! Its barely 15,000km old.
Reply #6May 21, 2012, 08:21:07 am
« Reply #6 on: May 21, 2012, 08:21:07 am »
Manual or self adjusting clutch cable? If it's auto replace it with a manual and if it's manual then adjust it
Reply #7May 21, 2012, 11:42:01 am
  • 3468
« Reply #7 on: May 21, 2012, 11:42:01 am »
I hear ya Tyler. As far as I can tell it travels all the way...(its auto)
Reply #8May 21, 2012, 11:59:01 am
« Reply #8 on: May 21, 2012, 11:59:01 am »
as far as i can tell, the clutch was not fully disengaging..
Reply #9May 21, 2012, 12:11:21 pm
  • 3468
« Reply #9 on: May 21, 2012, 12:11:21 pm »
So you reckon its gotta be that lever or?
Reply #10May 21, 2012, 12:27:49 pm
« Reply #10 on: May 21, 2012, 12:27:49 pm »
ive even seen the pressure plate be at fault..
your clutch finger is good? relay rod inside the trans is the right length?
how old is the clutch? whats the clutch cable like? manual/auto?
Reply #11May 21, 2012, 01:10:35 pm
  • 3468
« Reply #11 on: May 21, 2012, 01:10:35 pm »
The clutch was new in November and was barely driven during the winter.
Auto cable. Finger looks good. Rod is worn so I'm replacing it. Is there any way I can adjust an auto adjusting clutch cable?
Reply #12May 21, 2012, 04:12:42 pm
rs899
  • 647
« Reply #12 on: May 21, 2012, 04:12:42 pm »
Disconnect cable at both ends Remove and throw it in the dustbin.  Buy a manual cable.  It really feels a lot better and I like the fact that the tranny has no pressure on the arm when the clutch is not depressed.
Reply #13May 21, 2012, 05:07:58 pm
« Reply #13 on: May 21, 2012, 05:07:58 pm »
FWIW, mk1 clutch cables work in mk2 cars.. i have an 84 rabbit cable in my 92 Jetta.. the auto cable SUCKS..
throw the auto cable away. it never FULLY releases pressure on the clutch or throw out bearing..
Reply #14May 22, 2012, 12:24:01 am
  • 3468
« Reply #14 on: May 22, 2012, 12:24:01 am »
Ok ill do that
