Author Topic: Will a KKK Bv50 work on a 1.9 M-tdi?  (Read 17278 times)
April 17, 2012, 09:15:57 am
Sierra94
  • 123
    Dieselsmoke in every stroke... M-Tdi Mazda!!
    • http://www.garaget.org/sierra94
« on: April 17, 2012, 09:15:57 am »
Hi!
I´m about to buy a nearly unused KKK Bv50. The seller wants $150 for it, but I´m not sure it will spool up ok on my engine.
It came from a Audi 3.0 Tdi.
Whats your opinion? Will it work? I run a 12mm IP head and the engine works great now with a T3, but has some lag.
« Last Edit: April 17, 2012, 09:31:02 am by Sierra94 »
<-- My M-tdi Mazda B-1800 and my other cars
Reply #1April 17, 2012, 10:08:12 am
410
  • 581
Re: Will a KKK Bv50 work on a 1.9 M-tdi?
« Reply #1 on: April 17, 2012, 10:08:12 am »
The bv50 I think is very similar to the gtb2260 in size iirc.  If that's the case then it won't be an issue.  It should spool up faster than the t3 and way more efficient in the top end.  You won't regret it.  Just make sure your nozzles are big enough.  Bosio race 520's would be my choice but if money is an issue, try the .216 nozzles from veg injection.  The quality is great for the price and they are actually bigger than .216.
Reply #2June 01, 2012, 06:51:32 am
Sierra94
  • 123
« Reply #2 on: June 01, 2012, 06:51:32 am »
I ended up installing a brand new GT18V instead. I run the vanes fully opened up right now but it stills spools quicker than the T3 but maxes out at 1.8 bar (26 psi) Still with lots of black smoke and the fuel screw set very low  ;D
So next project will be a 2256 from an Audi or a 2556 from a BMW X5 3.0D. Should have more top end power.
Also installing a FMIC in the near future.
And an outside view  :)
« Last Edit: June 01, 2012, 07:13:04 am by Sierra94 »
Reply #3June 01, 2012, 09:12:51 am
« Reply #3 on: June 01, 2012, 09:12:51 am »
Why wouldn't you run a vane control before doing another turbo swap?  You would be able to get faster spooling along with an efficient higher max boost.
Reply #4June 01, 2012, 10:18:05 am
« Reply #4 on: June 01, 2012, 10:18:05 am »
coming from someone who ran open vanes for a VERY long time, it is WORTH it to control your vanes.
i just installed a GTB2056V on my 1.6D, and it spools as fast as a stock turbo with the vanes hooked up.
Reply #5June 01, 2012, 10:56:41 am
Sierra94
  • 123
« Reply #5 on: June 01, 2012, 10:56:41 am »
How will I get a more efficient HIGHER max boost with the vanes already at the most open position?
Reply #6June 01, 2012, 11:03:58 am
« Reply #6 on: June 01, 2012, 11:03:58 am »
you gotta close the vanes down a bit to get more boost..
but closing the vanes cuts the efficiency of the turbo..
26psi out of a GT18v is probably at about the top end of its efficiency spectrum anyways..
you need to either hook up a wastegate can up to operate your vanes, or go with a full manual control..
heres something else to look at:
my vnt20 (considerably bigger than your 18) absolutely WILL NOT SPOOL without the vanes operating. if the vanes are stuck open, the turbo will NOT boost.
but, with the vanes operational, it spools QUICK, and makes good boost till the wastegate can opens the vanes.
Reply #7June 01, 2012, 12:06:27 pm
Sierra94
  • 123
« Reply #7 on: June 01, 2012, 12:06:27 pm »
Ok. I will build a controller with cables and a wastegate can etc in the near future.
I think with a 12 mm head I have enought exhaust/heat to spool even a VNT20 with vanes almost fully open. But I´ll try a controller first
and the go for a bigger vnt.
Thanks for the input  ;)
Reply #8June 01, 2012, 02:04:36 pm
Henk
  • 111
« Reply #8 on: June 01, 2012, 02:04:36 pm »
using a VNT20 myself, and have a thread on how to operate the vanes using throttle position and boost, you're welcome to use it
I suspect we'll have similar engine setups. oh and i love your truck dude!
Mid Engine
Berg Cup
M-TDi
Caddy!
Reply #9June 01, 2012, 10:37:27 pm
Sierra94
  • 123
« Reply #9 on: June 01, 2012, 10:37:27 pm »
Thanks  ;)
Reply #10June 02, 2012, 03:34:17 am
Syncroincity
  • 727
« Reply #10 on: June 02, 2012, 03:34:17 am »
Water injection, too... :D  What kind of setup are you running, & how do you like it?
I have a Snow Performance system, not installed yet.
How long does it take you to run through a tank of fluid?
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
Reply #11June 02, 2012, 08:59:38 am
Sierra94
  • 123
« Reply #11 on: June 02, 2012, 08:59:38 am »
A devils own system, with a 5 gph nozzle. Starts injecton at 0.9 bar boost pressure. My tank holds almost 2 gallons. The system only inject when I´m hard on the go pedal. Not during normal freeway cruising and town driving. So the fluid holds up pretty good.
Reply #12June 02, 2012, 04:58:13 pm
Syncroincity
  • 727
« Reply #12 on: June 02, 2012, 04:58:13 pm »
Nice. I'm thinking about a tiny (0.5gph) nozzle pre-turbo, then a 4 or 5 at the manifold. I'll be getting my nozzles and mounts from Devil's... I got the pump and computer used on Ebay. ;)
JC McCavitt
'98 Jetta Wolfie
Reply #13June 03, 2012, 01:55:16 pm
Sierra94
  • 123
« Reply #13 on: June 03, 2012, 01:55:16 pm »
Why a nozzle pre-turbo? They only produce alot of moisture in the intercooler. Especially if you have highly placed inlet/outlets on the IC.
Reply #14June 06, 2012, 11:59:59 am
keaton
  • 90
« Reply #14 on: June 06, 2012, 11:59:59 am »
see my sig for a standalone VGT & LDA controller
http://dmn.kuulalaakeri.org/vnt-lda/
Quote from: Features
8x8 map for VNT & LDA control
 Use N75 solenoid based actuators
 Live configuration via USB interface and graphical map editor (no special software needed)
 Two VNT control modes:
    * Duty Cycle map - Uses RPM/TPS info to set VNT actuator position. Additional dampening can be added to improve engine response. No map sensor needed for this setup.
    * Target Pressure map - Specify requested pressure value on each control point. Vnt-lda will automatically move actuator until required pressure level is reached.
LDA table can be used to fine tune soot emissions and torque limiting on certain RPM-range.
Cheap and free :-)
Quote from: Requires:
    * RPM Engine speed sensor, use Honeywell GT101DC or alternator W-output as a source.
    * TPS Throttle position sensor (like Bosch "001")
    * MAP Manifold absolute pressure sensor for detecting amount of boost, for example 4bar Freescale MPX6400
    * Arduino AVR-microcontroller board, servos, n75 (or similiar) solenoid & vacuum actuators
« Last Edit: June 06, 2012, 12:01:40 pm by keaton »
2006 1.9L BRM 5-speed Manual... 100% Stock :(
Standalone VGT/VNT controller: http://dmn.kuulalaakeri.org/vnt-lda/
My CAN Bus video recorder: http://www.youtube.com/watch?v=2QuRBQzGs-c
