Author Topic: NEEDED. K24 Turbo.  (Read 5057 times)
March 17, 2012, 06:10:17 pm
One_punchmachinegun
  • 261
NEEDED. K24 Turbo.
« on: March 17, 2012, 06:10:17 pm »
Hi im looking for a k24 turbo, If some has one and wants to let go of it let me know. I perfer a healthly one but is not needed.
Email me a [email protected]
Thank you
« Last Edit: March 17, 2012, 07:55:29 pm by One_punchmachinegun »
“If anyone hears my words but does not keep them, I do not judge that person. For I did not come to judge the world, but to save the world." Jesus Christ
Reply #1March 17, 2012, 07:06:52 pm
Re: NEEDED. K24 Turbo.
« Reply #1 on: March 17, 2012, 07:06:52 pm »
i think he basically needs everything too.. like manifolds, oil lines, intake and exhaust pieces, everything..
am i right Tim?
cause im pretty sure i basically have you talked out of running a VNT, as well as your findings online.. they are starting to fail at an ALARMING rate..
Reply #2March 17, 2012, 07:59:25 pm
One_punchmachinegun
  • 261
« Reply #2 on: March 17, 2012, 07:59:25 pm »
No, the manifolds are not needed. I believe, but i maybe wrong. K24s will bold right up to a k14 manifold and downpipe right?
Reply #3March 17, 2012, 09:07:18 pm
« Reply #3 on: March 17, 2012, 09:07:18 pm »
do you have the proper K14 manifold? the downpipe is JUNK for performance applications.. it necks down to a little bigger than 1" internal diameter..
Reply #4March 18, 2012, 04:54:25 am
One_punchmachinegun
  • 261
« Reply #4 on: March 18, 2012, 04:54:25 am »
Since thats the case, I have a good friend that can make a good downpine. What would be a good size 2.5"?
I would assume i have the correct k14 manifold. Did VW make two different manifolds for the K14.
Reply #5March 18, 2012, 05:54:43 am
410
  • 581
« Reply #5 on: March 18, 2012, 05:54:43 am »
They made at least two different exhaust manifolds for the k14 that I've seen.  And at least 3 different kinds for the aaz engine.
Reply #6March 18, 2012, 07:13:33 am
JerryGTD
  • 89
« Reply #6 on: March 18, 2012, 07:13:33 am »
The exhaust manifold on my ECOdiesel with a K-14 is indeed different although very similar to the one from my 85 with a K-24.  I don't know how interchangable they are.
1991 Jetta GL ECOdiesel
Reply #7March 19, 2012, 03:52:23 pm
One_punchmachinegun
  • 261
« Reply #7 on: March 19, 2012, 03:52:23 pm »
bump. :) Some has to have one they are willing to let go. ;)
