Author Topic: HELP!!!!!! STRANDED REAR WHEEL BEARING BLOWOUT !!!!!  (Read 6960 times)
Reply #15March 04, 2012, 06:52:18 pm
bbob203
  • 1789
Re: HELP!!!!!! STRANDED REAR WHEEL BEARING BLOWOUT !!!!!
« Reply #15 on: March 04, 2012, 06:52:18 pm »
yep trying to get the drum off still its that race its on there good.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #16March 04, 2012, 07:00:40 pm
« Reply #16 on: March 04, 2012, 07:00:40 pm »
may have to take the stub axle off with everything still attached to it, and take it to the vice, so its not in such an awkward position..
in the end, you may have to replace the whole stub axle, bearings, drum, brake hardware n pads, and everything on that particular side..
Reply #17March 04, 2012, 07:25:33 pm
« Reply #17 on: March 04, 2012, 07:25:33 pm »
i know a guy in talmage.. he less then 20 min from summit racing..
http://www.globalgarage.biz/
440)796-1239
jeff good people... :D
jeff also has my #... i expect he has a stub sitttin round from his haldex mk1 conversion.. but if all else fails.. i have one..
biggest question is rear brake size.. and if all else fails.. you BREAK the drum... its only cast.. so once you get a hole in it it will crack/break rest of way.. but need to know what size drum for a replacement..
« Last Edit: March 04, 2012, 07:31:10 pm by CRSMP5 »
Reply #18March 04, 2012, 07:37:16 pm
  • 4551
« Reply #18 on: March 04, 2012, 07:37:16 pm »
I had this same problem about 6 months ago.  Bearing got so hot it welded itself to the stub.  I ended up being able to hit it hard enough with a chisel and heavy ball peen hammer and got it to snap off.  The thread was battered up but still had a few threads for the nut to catch on.  I was able to replace the bearing, I had a spare in the tool box, and squeeze the drum on best I could, eased the nut on and held it in place with the cotter key.  Then I drove at 40-45 mph for then next 75 miles and made it home.  4.5 hr trip went to 10.0 hrs.
I replaced the stub axles, the bearings and the end caps but the brakes were fine.
Best of luck on this.  Been on that road and it really bites that you HAVE to be somewhere in the morning.
Reply #19March 04, 2012, 08:22:18 pm
bbob203
  • 1789
« Reply #19 on: March 04, 2012, 08:22:18 pm »
ah yea Jeff Pilney I've dealt with him before good guy Ill probably give him a ring. I've got things figured out repacked my girlfriends car to accommodate me. luckily i work for an airline so i can fly for free so ill be back on Thursday to see if i can fix this bastard. In the meantime I'm gonna try to come up with the parts I need to get this back together.
03 Jetta wagon TDi
Reply #20March 04, 2012, 09:00:52 pm
  • 4551
« Reply #20 on: March 04, 2012, 09:00:52 pm »
Sounds like the only plan you can have at this point.  Good that you had a spare car, maybe just put the GF in a motel next to the car, have her get the parts and fix it.  Then fly up and bring the two home.  Love you too dear.
Reply #21March 04, 2012, 10:57:25 pm
Baron VonZeppelin
« Reply #21 on: March 04, 2012, 10:57:25 pm »
The 91 Jettas will have 200mm rear brakes/drums.
90-98 should be interchange.
A good propane torch should get it hot enough.
Might take 5 solid minutes though - and a slide hammer.
It sounds like you might have already nookered the axle beyond limits,
but you need to get e-Brake cable undone in there - could bend and bang backing plate enough probably to get at it.
Shoes, hardware (springs), drum are specific to 200mm
All else could be from 180mm donor
... well backing plate i'm not 100% certain if its the same.
actually you "could" have one side all 180mm for time being if thats what it takes to get it home for now.
fwiw
Reply #22March 06, 2012, 05:29:41 pm
Mark(The Miser)UK
  • 1557
« Reply #22 on: March 06, 2012, 05:29:41 pm »
Try pulling on the drum whilst rotating it, does it bind then? If so it may well still be a shoe catching issue. Shame the stub axle bolts are in the drum side.
Also they are either 15 or 16mm when you do get to them >:(
Newer replacement drums are soft machined steel that wear as fast as the pads [almost]. Old original ones are hard but brittle cast iron, which will smash off. They were hard because they ran the last of the asbestos shoes...
Mark-The-Miser-UK
Reply #23March 08, 2012, 03:54:37 pm
srgtlord
  • 797
« Reply #23 on: March 08, 2012, 03:54:37 pm »
Not to be a pest but....did you sucessfully disengage the brake shoes? There is a wedge in the upper left inside the brake drum that is only accessable with a long screw driver. You push it up and the shoes release.
Reply #24March 08, 2012, 03:56:34 pm
bbob203
  • 1789
« Reply #24 on: March 08, 2012, 03:56:34 pm »
beat it with a screwdriver turned into a chisel. for the hell of it i threaded the axle nut on it and cranked it hard... VOILA! the race cracked then i put the slide hammer back on it came right off. the axle would've needed replaced anyway it was grooved from the race spinning free on the axle. got a new axle and bearing kit today. gonna take the drum somewhere tomorrow morning to get the new outer races and inside seal installed.
 ;D ;D ;D
03 Jetta wagon TDi
Reply #25March 08, 2012, 07:41:30 pm
ToddA1
  • 434
« Reply #25 on: March 08, 2012, 07:41:30 pm »
Glad to hear!  I've always installed the races with a hammer and socket.  If you heat the drum, the races practically fall in.
-Todd
Reply #26March 08, 2012, 07:46:27 pm
  • 4551
« Reply #26 on: March 08, 2012, 07:46:27 pm »
If you put the races in the freezer you don't have to heat up the drum as much.  Maybe not at all.
Reply #27March 08, 2012, 07:46:59 pm
« Reply #27 on: March 08, 2012, 07:46:59 pm »
-Todd
I do both. Works like a charm :)
Reply #28March 08, 2012, 07:54:11 pm
ToddA1
  • 434
« Reply #28 on: March 08, 2012, 07:54:11 pm »
I used to do that and it works fine.  I'd always forget to put the races in the freezer until 5 minutes before they're ready to be installed.  The torch method is way faster and everybody knows that fire is cool.
-Todd
Reply #29March 09, 2012, 04:47:11 am
bbob203
  • 1789
« Reply #29 on: March 09, 2012, 04:47:11 am »
i tapped the old ones out with a punch sanded em down and used them to tap the new ones along with a big socket worked out great. now my problem is figuring out where these camber shims where placed ??? cuz i didnt relalize what they were til last night before bed?
03 Jetta wagon TDi
