Author Topic: Weird Noise  (Read 3968 times)
Reply #15February 28, 2012, 09:54:37 pm
steevz
  • 229
Re: Weird Noise
« Reply #15 on: February 28, 2012, 09:54:37 pm »
I don't know where mine is coming from, replaced the tensioner in case that was the problem. Sounds like more of an internal rubbing if that makes sense.. maybe it is the IP bracket.. or maybe it's the water pump? How does the WP sound when starting to fail?
Reply #16February 28, 2012, 10:57:01 pm
pointynoggin
  • 93
Re: Weird Noise
« Reply #16 on: February 28, 2012, 10:57:01 pm »
Take a 3' bit of hose stick one end in your ear and stick the other end around the pulleys you think are making noise.  You'll know what is is pretty quick.
Also look for metal shavings.  My cam sprocket rubs on the shield and makes shavings.
1991 Jetta 1.6TD, Giles Superpump,
Reply #17February 29, 2012, 05:50:46 pm
steevz
  • 229
Re: Weird Noise
« Reply #17 on: February 29, 2012, 05:50:46 pm »
Will give it a shot. Thanks.
