Author Topic: Weird Noise  (Read 4048 times)
February 23, 2012, 12:27:14 pm
Dozier
  • 18
Weird Noise
« on: February 23, 2012, 12:27:14 pm »
 Hi everyone,
 Does anyone elses IP make this funky noise?
http://s1126.photobucket.com/albums/l603/dozierrrr/?action=view&current=IMG_0648.mp4
thanks!
« Last Edit: February 23, 2012, 01:54:08 pm by Dozier »
Reply #1February 23, 2012, 12:46:04 pm
Re: Weird Noise
« Reply #1 on: February 23, 2012, 12:46:04 pm »
page not found.. links dead....
both here, and on the vortex too.. same dead link.
Reply #2February 23, 2012, 01:54:48 pm
Dozier
  • 18
Re: Weird Noise
« Reply #2 on: February 23, 2012, 01:54:48 pm »
maybe now?
thanks
Reply #3February 23, 2012, 02:48:55 pm
steevz
  • 229
Re: Weird Noise
« Reply #3 on: February 23, 2012, 02:48:55 pm »
I've noticed mine making a similar noise. Haven't spent time to try and figure it out yet though.
Reply #4February 23, 2012, 03:19:15 pm
smutts
  • 720
    ClackClackClackClackClack
Re: Weird Noise
« Reply #4 on: February 23, 2012, 03:19:15 pm »
Paint on the back of the cambelt squeaking on the intermediate shaft pulley..................Or not! ;D
Reply #5February 23, 2012, 04:31:43 pm
Dozier
  • 18
Re: Weird Noise
« Reply #5 on: February 23, 2012, 04:31:43 pm »
Just loosened it a little. Went away.
thanks everyone!
Reply #6February 23, 2012, 04:44:23 pm
Re: Weird Noise
« Reply #6 on: February 23, 2012, 04:44:23 pm »
thanks everyone!
means your timing belt was TOO TIGHT..
Reply #7February 23, 2012, 05:32:24 pm
Dozier
  • 18
Re: Weird Noise
« Reply #7 on: February 23, 2012, 05:32:24 pm »
thanks everyone!
yea...I know.  :o
Reply #8February 23, 2012, 05:48:04 pm
  • 4553
Re: Weird Noise
« Reply #8 on: February 23, 2012, 05:48:04 pm »
Another front seal saved from premature death.
Reply #9February 23, 2012, 06:27:11 pm
JamesT
  • 151
Re: Weird Noise
« Reply #9 on: February 23, 2012, 06:27:11 pm »
That's the sound tensioners make when they're yelling at you.
93 Golf - AAZ with some fueling
78 Rabbit - 1.5 DIESEL (finally)
[(+)===o===(+)]
 (++\==o==/++)
Reply #10February 23, 2012, 07:29:28 pm
Re: Weird Noise
« Reply #10 on: February 23, 2012, 07:29:28 pm »
was just abt to reply to the pm... but yea over tight belt is 1st guess always..
Reply #11February 24, 2012, 01:55:54 pm
Dozier
  • 18
Re: Weird Noise
« Reply #11 on: February 24, 2012, 01:55:54 pm »
Well it did go away but now its back. I took the accessorie belts off to make sure and it's still there. Im not going to worrie with it. It runs fine.
thanks everyone!
Reply #12February 24, 2012, 06:39:03 pm
Re: Weird Noise
« Reply #12 on: February 24, 2012, 06:39:03 pm »
thanks everyone!
if you ran the belt too tight for too long, then the tensioner is probably wiped out, and if the tensioner seizes up, your timing belt breaks, and then your head needs a rebuild, or replace...
that sound like fun? then fix the noise..
Reply #13February 25, 2012, 01:09:17 pm
steevz
  • 229
Re: Weird Noise
« Reply #13 on: February 25, 2012, 01:09:17 pm »
I have a bit different of a noise.. it was more like a wub, wub, wub, wub.. like rubber on metal I guess. Now it's more of a metal on metal.. not loud, but there..
Took off my upper timing cover to check it out today.. brand new continental tbelt, worn on the sides down to the metal brading in two spots. I can see the sound happens as those spots go into the tensioner. Getting a new tensioner today. But any ideas on why only two spots of the belt would have been rubbing and wearing? Is the timing belt still safe to run?
Reply #14February 25, 2012, 08:34:05 pm
damac
  • 531
Re: Weird Noise
« Reply #14 on: February 25, 2012, 08:34:05 pm »
Your video still looks terrible, the belt is trying to ride off the pulley and its stopping because of the edge on the tensioner.
I got my jetta like that a year and a half ago and it had half a timing belt!  Crapped myself when I got it home, it drove fine on the way home :)
When I first searched for why it was happening, I thought it was a bad adjustment of the brackets that hold the ip.  But I couldn't adjust it away with a new timing belt/tensioner and the same thing was starting to happen.  Starts out rubbing, let it keep going and it slowly grinds the belt down.
What mine actually ended up being was the mainshaft bushings on the pump were so oval shaped that you could grab the pulley and rock it side to side with your hands.  I wasn't able to get a straight edge across the pulleys.
Ended up going with a spec'd bottom end of another pump and slapped my turbo bits on it and was amazed at the difference.  Then it took me a handfull of tries to get it perfect but then I was able to adjust where the ip sits and tracks on the belt.  Now its still riding down the middle almost 20,000 miles later.  No funky noises like that or belt shavings, etc.
If I was you I would investigate this and fix it now.  Maybe you will be lucky and your ip bracket is just out of adjustment.
1985 turbo diesel jetta
