Author Topic: Building AAZ motor; meet Harley  (Read 116882 times)
Reply #210August 14, 2013, 07:53:19 am
Re: Building AAZ motor
« Reply #210 on: August 14, 2013, 07:53:19 am »
Wait a second, this is Crazy Mike's thread, not Bob's.
I forgot about the hose/liquid method for finding TDC.  Thanks for the reminder.  You can stick the end of the tube into a cup of liquid and watch for when the bubbles stop and the liquid starts getting sucked into the hose.
Some of the early 1.9s used the same tensioner as the 1.6s.  I believe the stud size is different.  Upside to the 1.6 tensioner is that it is less expensive.  Downside is it doesn't tell you how tight to make the belt.  Regardless, when tensioning the belt, it is important that you do move all the slack to the tensioner area and that the pump is not locked and the cam sprocket is able to turn on the cam.
« Last Edit: August 14, 2013, 07:56:40 am by libbydiesel »
Reply #211August 14, 2013, 08:09:39 am
« Reply #211 on: August 14, 2013, 08:09:39 am »
i usually just let the valve cover on and i put the belt on where ever it falls, then i turn the engine over, if something hits i move the belt one tooth on the cam until nothing hits anymore.  then for injection timing i remove the injection lines and turn over the engine and until the #1 port on the injection squirts pretty close to tdc on the fly wheel.  been doing it that way for years.  we don't need all these wanna be engine ears on here over thinking the timing process, its real easy.  then to tension it i just put it on tight, u can tell when the slack is good and tight the engine will sound super charged, then u just back off the tensioner a hair until it don't sound that way,  like i said i been doing this for years i know what i am doing.
Reply #212August 14, 2013, 11:59:54 am
« Reply #212 on: August 14, 2013, 11:59:54 am »
bob as in sponge bob.. :D who else do you know that makes crabby paddy?
its all bout tricks... i never heard of the water method... but find no reason for it to not work.. :D
depends on the stud size like libby said giz.. for what ever odd reason they went back to a smaller stud... they started with small stud.. upgraded to the big stud as people were breaking little studs back in the 70s.. then went back to little studs so they break again..
Reply #213August 14, 2013, 12:32:26 pm
« Reply #213 on: August 14, 2013, 12:32:26 pm »
If this worked I'd say congratualtions..
Chris lol, you're one to talk about wording thigs to be understood correctly.
Reply #214August 14, 2013, 12:40:00 pm
« Reply #214 on: August 14, 2013, 12:40:00 pm »
Lol@chris
Reply #215August 14, 2013, 12:58:09 pm
« Reply #215 on: August 14, 2013, 12:58:09 pm »
<----- not a mod... why i do not want to be one.. on top of my political views really suck...
Reply #216August 14, 2013, 07:38:33 pm
CrazyAndy
  • 739
« Reply #216 on: August 14, 2013, 07:38:33 pm »
It seems I have run into a snag.  With my PD intake choice, coupled with my T3, the turbo compressor housing hits the intake manifold.
It's hard to see in the flash, but the compressor housing is butted up against the intake, whereas the turbo flange itself has about another 1/8-3/16 to be able to correctly sit on the exhaust flange.  I think I may need a turbo spacer here.
Reply #217August 14, 2013, 07:44:58 pm
« Reply #217 on: August 14, 2013, 07:44:58 pm »
***ty buzzzzzzzz
Reply #218August 14, 2013, 07:46:47 pm
« Reply #218 on: August 14, 2013, 07:46:47 pm »
just send the manifold to 8v so customs can loose it... :P
yea.. you know.. you need to ask bbob abt his turbo/mani set up.. we knew that fit was tight... had to cut things off his pd manifold.. and your cold side way bigger...
Reply #219August 14, 2013, 07:54:50 pm
CrazyAndy
  • 739
« Reply #219 on: August 14, 2013, 07:54:50 pm »
Actually it's the same on the outside, the difference is in the inducer size on the compressor.  I already lined them up, and the stock housing would have done the same thing.  I'll give bbob a PM, hopefully I can find a solution.  I really wish VW hadn't gone with this weird flange right about now, or I'd have just messages saying 'had to order spacer'.  I really hope this doesn't affect my DP either.
EDIT:  Wait . . Lucas . . I've got it!  Lucas, hit me up if you get the chance tomorrow.  I wanna see if your local machinist that cut your flywheel adapter might be looking for work. :)
« Last Edit: August 14, 2013, 08:07:18 pm by CrazyAndy »
Reply #220August 14, 2013, 08:27:38 pm
Reply #221August 15, 2013, 05:34:13 am
« Reply #221 on: August 15, 2013, 05:34:13 am »
was just going to recommend what Libby just posted. You could thin that down to around 1/4" or leave it 1/2" and have some space.
Mine worked out as the custom intake tubes were slanted just enough so I didn't have an issue :D
Reply #222August 15, 2013, 06:06:25 am
« Reply #222 on: August 15, 2013, 06:06:25 am »
you don't think a grinder could solve this problem?
Reply #223August 15, 2013, 06:12:34 am
« Reply #223 on: August 15, 2013, 06:12:34 am »
Did that with the AAZ manifold but this being the PD I don't know. I only needed to take off an 1/8" of the aaz manifold. Also check to see if clocking it will help if you haven't already done that.
Reply #224August 15, 2013, 06:50:33 am
« Reply #224 on: August 15, 2013, 06:50:33 am »
The site I linked also has 3/8 and stainless.  $40 and 4 gaskets later it'd be done.
