Author Topic: Turbo Oil Return Line  (Read 4371 times)
February 21, 2012, 01:51:49 pm
ein bora
  • 377
« on: February 21, 2012, 01:51:49 pm »
This is the bottom of my VNT20 that's finally on my 1.9 IDI build, that's going into my passat gas to diesel project. I'm I safe in assuming that both the center holes are the oil return lines.
Thanks.
If you can't take advice - then you can't be helped!
Reply #1February 22, 2012, 08:25:30 pm
ein bora
  • 377
Re: Turbo Oil Return Line
« Reply #1 on: February 22, 2012, 08:25:30 pm »
Maybe not enough information - it's a Garret GT2056.
Reply #2February 22, 2012, 10:51:51 pm
  • 2926
« Reply #2 on: February 22, 2012, 10:51:51 pm »
Is that small hole threaded?
 Looks like it's used to hold/seal something against the other hole that opens into the chamber.
Reply #3February 23, 2012, 05:25:40 am
« Reply #3 on: February 23, 2012, 05:25:40 am »
If you want better guesses then show pictures of all the ports in the center cartridge.
Reply #4February 23, 2012, 07:15:01 am
« Reply #4 on: February 23, 2012, 07:15:01 am »
i would be thinking that it may have a liquid cooled center section...
Reply #5February 23, 2012, 11:40:12 am
rallydiesel
  • 1880
« Reply #5 on: February 23, 2012, 11:40:12 am »
I have a gt2559v with a similar arrangement. On it, the small hole is the oil feed and the larger is the return.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #6February 23, 2012, 12:30:16 pm
« Reply #6 on: February 23, 2012, 12:30:16 pm »
that was the other option i was thinking..
OP, is there an oil feed on the top of the center section in the normal position?
Reply #7February 23, 2012, 01:31:26 pm
ein bora
  • 377
« Reply #7 on: February 23, 2012, 01:31:26 pm »
Quote from: R.O.R-2.0
[/quote
Yes - there is one on top too. But maybe rallydiesel is correct as I found this while searching, it's known as a oil inlet/outlet flange kit - but I couldn't find anything that goes along with it. As you can see in the pic the holes aren't threaded.
Reply #8February 24, 2012, 04:27:12 am
ein bora
  • 377
« Reply #8 on: February 24, 2012, 04:27:12 am »
My error - after more digging the holes are tapped on the flange kit making for easy feed and drain solutions. The threads for oil feed is 1/8" npt  and the threads for oil return is 3/8" npt. I've contacted the supplier to see if it'll work on a GT2056 as they have it listed fitting a GT1241.
Thanks to all for the info. Helped immensely as usual.
