Author Topic: Got a new 10mm injection pump.. couple questions?  (Read 11290 times)
Reply #30January 11, 2012, 05:53:49 pm
BillyWillicker
  • 111
Re: Got a new 10mm injection pump.. couple questions?
« Reply #30 on: January 11, 2012, 05:53:49 pm »
Cool!!  Does the accelerator pedal push back against your foot when its all wound up or is it not even noticeable?
Reply #31January 11, 2012, 06:37:39 pm
« Reply #31 on: January 11, 2012, 06:37:39 pm »
I can pull the needed 57-5800 rpms in 1st through 4th gears to get the rollers skipping. It stops injecting immediately and power just cuts off.
Much like a gasser would when rev limiter is hit. Also my governor is no longer a spring, but a solid piece.
yup.. same deal on the governor.
5750 is the end of the power..
