Author Topic: Brand Newbie here - working on a Land Speed Project (1.5L or less diesel).  (Read 33455 times)
Reply #75January 17, 2012, 08:14:01 am
UnderPSI
  • 109
Re: Brand Newbie here - working on a Land Speed Project (1.5L or less diesel).
« Reply #75 on: January 17, 2012, 08:14:01 am »
FYI, some where north of 28psi on a 1.5, head studs pull out of the block.
Suzuki Samurai 1.6
Reply #76January 17, 2012, 08:22:02 am
« Reply #76 on: January 17, 2012, 08:22:02 am »
i ran ~35 psi on stock head bolts, and a stock gasket.. 1.5D.. the trans end of the block finally failed, and cracked all to hell.
thats why he is going to put a 1.5 rotating assembly in a 1.6TD block.. (a 1.5TD with strong head bolts/studs)
Reply #77January 17, 2012, 08:31:22 am
UnderPSI
  • 109
« Reply #77 on: January 17, 2012, 08:31:22 am »
Do not lower compression,trust me..
If i built some think like this,maybe i use 1.4 na or 1.3 na base engine.Both engine has several benefit against 1.6 or 1.9
You can run less compression without a problem, it will even start decent.
Suzuki Samurai 1.6
Reply #78January 17, 2012, 08:47:30 am
Jetmugg
  • 530
« Reply #78 on: January 17, 2012, 08:47:30 am »
UnderPSI - as I was searching the forum on this topic, I saw your thread about the big valve heads, including a 1.9 head with very big valves.    Your Samurai looks bad-to-the-bone.  Extremely nice job on that truck.   Have you ever run a 1.9 head on a 1.5 displacement engine?
Steve.
Reply #79January 17, 2012, 09:03:53 am
UnderPSI
  • 109
« Reply #79 on: January 17, 2012, 09:03:53 am »
I haven't, don't see the need.
Suzuki Samurai 1.6
Reply #80January 17, 2012, 09:28:43 am
Jetmugg
  • 530
« Reply #80 on: January 17, 2012, 09:28:43 am »
Are you running the big valve 1.6 head in your Samurai?
Reply #81January 17, 2012, 11:51:49 am
« Reply #81 on: January 17, 2012, 11:51:49 am »
what "BIG VALVE" 1.6 head are you talking about? ALL 1.6 heads have the same valves..
Reply #82January 17, 2012, 12:51:07 pm
Jetmugg
  • 530
« Reply #82 on: January 17, 2012, 12:51:07 pm »
This one...
http://www.vwdiesel.net/forum/index.php?topic=26316.0
Reply #83January 17, 2012, 05:18:41 pm
UnderPSI
  • 109
« Reply #83 on: January 17, 2012, 05:18:41 pm »
I haven't yet, was busy with other projects, ordered my head studs and a low pressure turbo today though.
Suzuki Samurai 1.6
Reply #84February 25, 2012, 10:41:28 am
Aki-76
« Last Edit: February 25, 2012, 10:43:00 am by Aki-76 »
Reply #85February 25, 2012, 11:06:06 am
Reply #86February 25, 2012, 11:49:07 am
Aki-76
« Reply #86 on: February 25, 2012, 11:49:07 am »
wait for dyno sheet..   ;D
Reply #87February 25, 2012, 11:52:51 am
« Reply #87 on: February 25, 2012, 11:52:51 am »
the dyno is prolly gonna make me s#!t a buick...
nothing surprises me with you tho, Aki..
Reply #88February 28, 2012, 08:15:54 am
Jetmugg
  • 530
« Reply #88 on: February 28, 2012, 08:15:54 am »
Aki - that 1.3 Polo engine looks deadly.  It is a shame that we don't have those engines in the USA.  I have heard rumors of some people who have imported "Gray Market" VW diesel engines to the US from Europe, but there doesn't seem to be a good source for such services.
I would be happy to give that engine a good home, and send it back when I am done, if you are interested in having your engine compete for a Land Speed Record.
Steve.
Reply #89March 16, 2012, 11:34:23 am
