Author Topic: Flywheel threadlocker?  (Read 7926 times)
Reply #15January 04, 2012, 07:30:03 am
somolovitch3
  • 290
Re: Flywheel threadlocker?
« Reply #15 on: January 04, 2012, 07:30:03 am »
Maybe this should end up as a sticky of what not to do.
Clarification:
        N 902 061 03  M10x1x19.5  (These are sholdered)  Comes with Blue Loctite Stripe  P Plate to Crank Bolts  6 needed
        N 100 134 01  M7x40x20    (These are 12pt 9mm heads)  No Loctite  Flywheel to P Plate  9 needed
Crank Bolts are big fat suckers, Flywheel Bolts are skinny long ones.
And my bad agaain...25 ft lbs on Lubricated bolts is more like 30 + ft lbs on dry bolts....Yep, over torgued them sukers. :'( So Autohaus AZ to the rescue. Should get new bolts come Fri morn..............Gods I hope!
Will get this right (lol) ...........well..........heck yes!
Thanks for all the help!
pps: Check broke vw for neat trick using combo wrench and bolts to "lock" the P Plate to loosen/tighten those 6 bolts
« Last Edit: January 04, 2012, 07:33:30 am by somolovitch3 »
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
Reply #16January 04, 2012, 10:58:03 am
pointynoggin
  • 93
« Reply #16 on: January 04, 2012, 10:58:03 am »
funny,  I bought 9 of the long skinny ones but only needed 6.  Mine is a 91 jetta TD.
1991 Jetta 1.6TD, Giles Superpump,
Reply #17January 04, 2012, 05:44:13 pm
BigVWman
  • 332
« Reply #17 on: January 04, 2012, 05:44:13 pm »
190/200mm clutch uses 6, 210mm clutch uses 9!
Tim
83 rabbit shell 92 cabby tdi conversion, 91 cabby aba conversion, 87 cabby,  87 gti,  01nb tdi new project,00 1.8t nb, 98 ranger,92 f150 flareside(its pink) 97 cabrio and a 00 cabrio!
Reply #18January 04, 2012, 07:42:01 pm
« Reply #18 on: January 04, 2012, 07:42:01 pm »
the 210mm on my TD originally had 6.. only the later 210s had 9 bolts. from what ive seen atleast..
Reply #19January 05, 2012, 02:30:05 am
somolovitch3
  • 290
« Reply #19 on: January 05, 2012, 02:30:05 am »
Durn!...Got Caught! ;D .......Clutch package out of a 2.0 Jetta .... And yes, it is a 210 mm. 8)
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
Reply #20January 05, 2012, 04:20:35 am
« Reply #20 on: January 05, 2012, 04:20:35 am »
I didn't think the 1.6TD ever had a 210mm. All the 210mm I have seen have been 9 bolts.
Reply #21January 05, 2012, 09:27:01 am
somolovitch3
  • 290
« Reply #21 on: January 05, 2012, 09:27:01 am »
IMPORTANT INFO!!!!!!!!
Just got off phone with Loctite, and:
      1) You can use Red on either side of the blue that is already applied to a bolt.
      2) IT DOES act like an "oil type" lubricant. If you want 15 ft lbs, torque to
          between 8 and 10 ft lbs. I do not think this applies to the pre-applied.
Bolts will (hoping with crossed fingers) be here on Fri "by end of business day". Or when the UPS guy dropps by.
Will keep you all in the loop.
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
Reply #22January 05, 2012, 12:43:22 pm
« Reply #22 on: January 05, 2012, 12:43:22 pm »
i could be wrong. maybe they did only have 200mm clutches.. would make sense as to why my plate only had 6 bolts..
Reply #23January 07, 2012, 12:45:03 am
somolovitch3
  • 290
« Reply #23 on: January 07, 2012, 12:45:03 am »
UPS guy got here, got the bolts in. 22 ft lbd does not seem like a lot, its that 1/4 turn that REALLY tightens things up. A little blue and 10 ft lbs later, the flywheel is attached. Trans goes in come morning.
Hummmm, gots us some snow coming down now.....what joyfull fun this could be!
Thanks once again to all of you for your help.
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
Reply #24January 08, 2012, 04:01:14 pm
somolovitch3
  • 290
« Reply #24 on: January 08, 2012, 04:01:14 pm »
Okay, First........
                                 THANK YOU ALL!!!!!!!!!!!!!!!!!!!!
Actually that's it.
Got the trans in, everything hooked up (Except the backup lites) and  crusied......NOT! :o.
Gone are my 1, 3, 5 shifts......25mph in fifth....not so easy now....Which is good....might be able to get better than 30 mpg.
Okay, the trans I took out was an FK close ratio...I thought I was going to .....ummm you know....ummmmm . Anyway that idea fell through. So I am back with an FF. Kept the short(ish) shifter stuff.
Once more with feeling........
                             TANKS ALL!!!!!!!!!!!!!!!!!!
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
