Author Topic: 020 trans fluid level check.  (Read 4701 times)
January 02, 2012, 11:50:09 am
trent77
  • 217
« on: January 02, 2012, 11:50:09 am »
Ok, I know I fill the trans with 2 qts. But to top off if I lose any, or just to check it, is there a plug to pull where the fluid should run out when full? I fill at the speedo cable hole, but it doesn't run out of there when full. Thanks for the help. It is a eco diesel trans on an aaz engine.. the trans is a 91. Thanks
Trent
91 (former)eco jetta now aaz (sold to Ben)
05 passat tdi (sold)
77 westfalia
06 GMC Duramax
10 Jetta sportwagen tdi
81 Rabbit pickup (Caddy)
Reply #1January 02, 2012, 11:52:35 am
Re: 020 trans fluid level check.
« Reply #1 on: January 02, 2012, 11:52:35 am »
depends on body style and trans. Eco trans should have the later 5th housing so you only add until it comes out, earlier style you add until it comes out and then shut it and add 4oz more.
All you ever wanted to know and things you don't is found here.
http://www.brokevw.com/
Reply #2January 02, 2012, 04:31:42 pm
somolovitch3
  • 290
« Reply #2 on: January 02, 2012, 04:31:42 pm »
Would you believe 2.1Qts? 2 whole quarts and then 3.2 oz more.
for checking the angle of the trans dictates how to check, just filling to the "fill"  hole.............uhhhhhhhhhhh.....................hummmmmmmmmmmmm................     might leave the 5th gear a little dry.
Drain it all out, measure it and put it back in? Add if needed?
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
Reply #3January 02, 2012, 08:21:54 pm
« Reply #3 on: January 02, 2012, 08:21:54 pm »
R.O.R.2-0 and I have figured out a way to read off the speedo gear as though it were a dipstick.
I do believe we figured half of the speedo mesh gear to be covered in oil was a full 020 trans. 2.1qt.
Reply #4January 02, 2012, 09:13:24 pm
mystery3
  • 774
« Reply #4 on: January 02, 2012, 09:13:24 pm »
If my math is correct, not likely, that would make it exactly 2 liters, the metric system is a beautiful thing.
Reply #5January 03, 2012, 05:10:54 am
« Reply #5 on: January 03, 2012, 05:10:54 am »
You wouldn't have to drain it all. If you have the old 5th housing you could just open the fill plug and let it drain from there until it stopped or slowed to a point that it is rediculous. Put the plug in and fill the rest from the speedo hole. I usually go the 4oz instead of the 3.2 as there is always some oil left in my measure and I don't think .8oz too much is as bad as anything low.
« Last Edit: January 03, 2012, 03:42:10 pm by theman53 »
Reply #6January 03, 2012, 10:28:21 am
« Reply #6 on: January 03, 2012, 10:28:21 am »
yup.. half way up the gear teeth. that be the full mark. i always check my oil with my speedo gear..
 8)
