Author Topic: 11MM ARP studs for my old 1.6?  (Read 6891 times)
November 20, 2011, 07:23:11 pm
monomer
  • 414
« on: November 20, 2011, 07:23:11 pm »
Plan to make it a TD
Are these the right studs?
ARP 1.5 8 valve head stud set  12 pt nuts with under cut studs 11mm thread 204-4701 $119.99
http://headbolts.com/Volkswagon-Audi-diesel-fasteners.html
Will a stock fibre gasket hold up well to 20psi? Or do I need an AAZ?
www.michiganvw.org
Reply #1November 20, 2011, 07:26:14 pm
Re: 11MM ARP studs for my old 1.6?
« Reply #1 on: November 20, 2011, 07:26:14 pm »
im running stock gasser stretch bolts, stock fiber head gasket, stock n/a block and head, all with a VNT bolted to it, pushing out over 20psi..
havent had one spec of trouble from it. its usually 30+psi that the fiber gaskets dont like..
dont see any reason why you would NEED an aaz head, unless you want to lower your compression, and run more boost than the factory compression allows.
and i wouldnt use undercut fasteners if i were gonna use studs..
Reply #2November 20, 2011, 07:31:04 pm
monomer
  • 414
« Reply #2 on: November 20, 2011, 07:31:04 pm »
I have a new fibre gasket gasket here, guess ill run that.
Should I order studs or just go with the non-stretch bolts that the 11mm block came with? I'd need a new set, as these are ROUGH. Wish ARP sold proper bolts for this car.
It says 1.5l on the site, they gonna work on my 1.6?
www.michiganvw.org
Reply #3November 20, 2011, 09:30:04 pm
RustyCaddy
  • 395
« Reply #3 on: November 20, 2011, 09:30:04 pm »
here is a nice write-up on head studs
http://www.vwdiesel.net/forum/index.php?topic=21948.0
Reply #4November 20, 2011, 09:43:09 pm
monomer
  • 414
« Reply #4 on: November 20, 2011, 09:43:09 pm »
Great link!
I think i'll get a set of the studs listed.
www.michiganvw.org
Reply #5November 20, 2011, 10:04:00 pm
monomer
  • 414
« Reply #5 on: November 20, 2011, 10:04:00 pm »
ARP # 204-4701 Ordered via http://lightningmotorsports.com
Total came out to JUST under $100 WITH shipping.
Site seems a bit shady, but google reviews turned up a lot of positive reviews. Mostly about arp stuff on the cheap.
www.michiganvw.org
