Author Topic: Where and how measure piston protrusion  (Read 2552 times)
October 11, 2011, 07:58:59 pm
pointynoggin
  • 93
« on: October 11, 2011, 07:58:59 pm »
I put together a 1.6td short block.  It used to have a 3 notch HG.
When I use a straight edge and feeler guage I get different protrusion results depending on if I push the piston to one side or the other when measuring in the plane of crank rotation.
When I measure at points inbetween the cylinders, where the rocking of the piston has no effect it is a 1 notch.  When I measure at points near the side of the block it is either a 1 notch or 2 notch depending on which side I measure and which way the piston is sitting in the bore.
I have new .40 over pistons and a block machined to match the pistons.  deck lightly skimmed.
anyone have an idea of what measurement is right?
1991 Jetta 1.6TD, Giles Superpump,
Reply #1October 13, 2011, 10:12:57 am
pointynoggin
  • 93
Re: Where and how measure piston protrusion
« Reply #1 on: October 13, 2011, 10:12:57 am »
Well then I will try a 1 notch.
Reply #2October 13, 2011, 02:53:33 pm
Mark(The Miser)UK
  • 1557
« Reply #2 on: October 13, 2011, 02:53:33 pm »
Best policy is to go for the thickest measured point.  Like driving under a height restriction, you have to allow for the ariel, or roofrack...
Mark-The-Miser-UK
