Author Topic: K14 gasket ???  (Read 3119 times)
September 30, 2011, 02:19:04 pm
hippiekiller
  • 73
K14 gasket ???
« on: September 30, 2011, 02:19:04 pm »
My local parts house is having some problems with this, so I'd thought I would ask...Is there a gasket between the turbo and the exh. manifold?  They can't seem to find one in the catalogues...
  Apparently 96 was the changeover year from the k14 to the k24, so there might be a couple of different options?
Thanx for reading....
95 jetta, 2"lift
92 dodge diesel too much to list
Reply #1September 30, 2011, 02:46:51 pm
Re: K14 gasket ???
« Reply #1 on: September 30, 2011, 02:46:51 pm »
there is no gasket., make sure both surfaces are perfectly straight
Reply #2September 30, 2011, 03:14:38 pm
jb86
  • 102
Re: K14 gasket ???
« Reply #2 on: September 30, 2011, 03:14:38 pm »
I have a k14, k24 and a t3
From 3 different cars: 1984 jetta, 1991 Eco diesel, and 1985 MF turbo diesel jetta
All use the same gaskets
I bought from emiata.com/prothe/Hans autohaus/or whatever he's going by today
Theres a set of 2 metal gaskets
You only need the one that's angled in on the 2 sides
 Jon
Reply #3September 30, 2011, 07:03:42 pm
jb86
  • 102
Re: K14 gasket ???
« Reply #3 on: September 30, 2011, 07:03:42 pm »
try this
http://www.hansautoparts.com/Product.aspx?16TurboGasket.htm
ive used these on 2 engines. the angled side one is what you want.
jon
Reply #4September 30, 2011, 07:37:39 pm
Blocksmith
  • 261
    Wrench Lurker
Re: K14 gasket ???
« Reply #4 on: September 30, 2011, 07:37:39 pm »
It seems that there is some discrepancy as to whether these turbos even got a gasket or not. I have to chalk one up for the no-gasket-needed side, as when I received my K14 (complete with mani), there was no gasket.
Green 83 Rabbit 4dr, 5 speed ACH trans swap, ported 1.6D mech lifter w/ vnt15, na pump w/ gov mod, gasser intake mani, 2.5" exhaust, bilstein sports and cut mk2 springs, ss brake lines, 14" vw bottlecaps
Reply #5October 01, 2011, 06:13:45 am
jb86
  • 102
Re: K14 gasket ???
« Reply #5 on: October 01, 2011, 06:13:45 am »
I've pulled the turbos off all 3 of my cars - my 91 jetta with 1985 MF engine (T3), 2 parts cars- 91 Eco diesel (K14) and 84 turbo diesel (K24)
All had gaskets (as I recall)
Why wouldn't you use a gasket if you can get one?
It's only about $7
It makes an isolation between the 2 metal surfaces
Jon
Reply #6October 01, 2011, 06:19:49 am
rallydiesel
  • 1880
Re: K14 gasket ???
« Reply #6 on: October 01, 2011, 06:19:49 am »
The Bentley states there is no gasket. Any gaskets available out there are 3rd party and not actually required. As Trevor mentioned, just make sure the surfaces are clean.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #7October 01, 2011, 08:31:37 am
Re: K14 gasket ???
« Reply #7 on: October 01, 2011, 08:31:37 am »
Correct. You do not need a gasket unless the metal surfaces are damaged. It would be a good idea to file down the high spots that normally form around the bolt holes but it probably isn't required. Some people use a very, very thin bead of RTV but personally I just go metal on metal.
