General Information
Troubleshooting
low oil pressure
Topic: low oil pressure (Read 6744 times)
September 24, 2011, 07:04:51 pm
low oil pressure
September 24, 2011, 07:04:51 pm »
I just changed main and rod bearings <500km ago as well as lifters about 20,000km ago.
All the bearings were done when I built the engine about 40-50k ago. So the I'M shaft bearings are a little old but from what could see they looked ok.
I know the oil pump would be the next logical spot to go.
Opinions?
Cold. Idle 2000 3000+
50 75 100+
Warm 25 30/40 50
HOT 5-10 12 <20
Those numbers seem really low to me for having fresh bearings.
I'm running lubro moly fully synthetic 5w35 ( or 5w40)
It's a 1.9 aaz with a really old garret t3 from a previous 1990 1.6td.
I'm wondering if the turbo is spilling the pressure.
I changed the cold side seals and bearings but the hot side was fused shut.
Blue 2009 CR140 Jetta CBEA/CJAA. Malone stage 2. EGR/DPF/Exhaust-valve deletes. 2.5" open exhaust. ADP Turbo swap. 1-stage nitrous kit.
THROWN ROD
September 24, 2011, 07:38:22 pm
Wayland
Re: low oil pressure
September 24, 2011, 07:38:22 pm »
Did you replace the oil pump when you built the engine, or at least measure the gear backlash?
84 Grumman Olsen Kubvan
93 Dodge CTD Truck
September 24, 2011, 07:47:38 pm
September 24, 2011, 07:47:38 pm »
I did not!
I'm asking if you all reckon an old turbo bleeds more oil or a worn pump causes lower pressure.
THROWN ROD
September 24, 2011, 07:50:18 pm
Wayland
September 24, 2011, 07:50:18 pm »
I would strongly suspect the pump.
93 Dodge CTD Truck
September 24, 2011, 08:08:07 pm
September 24, 2011, 08:08:07 pm »
Even if the turbo is really old? It still boosts great though...
I'll replace the pump.
THROWN ROD
September 24, 2011, 10:10:40 pm
September 24, 2011, 10:10:40 pm »
You can prime the pump with a drill and watch to see how much flows past the cam journals.
I've had those bleed off oil pressure.
September 24, 2011, 11:06:27 pm
September 24, 2011, 11:06:27 pm »
Hmm that's interesting although I wouldn't know what is too much?
THROWN ROD
September 26, 2011, 10:22:36 pm
September 26, 2011, 10:22:36 pm »
I hadn't done this before,.. but knew when it was flowing too much oil from journal 5.
I did check it with plastigauge after seeing it.
September 26, 2011, 10:26:50 pm
September 26, 2011, 10:26:50 pm »
The head isn't very old but the turbo and pump are very old. Especially in comparison. were yours pretty aged by this point?
THROWN ROD
September 27, 2011, 09:15:24 am
rallydiesel
September 27, 2011, 09:15:24 am »
Where are you reading from? Those numbers don't seem that terrible. I had an oil pressure gauge that read about 10 psi too low (VDO). Is your oil warning light blinking?
Last Edit: September 27, 2011, 09:17:11 am by rallydiesel
1991 Jetta TD - sold
2001 Golf TDI - Son's
September 27, 2011, 11:20:17 am
September 27, 2011, 11:20:17 am »
No blinking lights. Read from the cylinder head.
THROWN ROD
Reply #11
September 27, 2011, 02:17:57 pm
BigVWman
Reply #11 on:
September 27, 2011, 02:17:57 pm »
numbers aren't super bad. Doesn't head oil sender trigger a light at about 4.5psi and filter flange somewhere around 18-23 at 2000rpm?
Tim
83 rabbit shell 92 cabby tdi conversion, 91 cabby aba conversion, 87 cabby, 87 gti, 01nb tdi new project,00 1.8t nb, 98 ranger,92 f150 flareside(its pink) 97 cabrio and a 00 cabrio!
Reply #12
September 27, 2011, 02:36:29 pm
Reply #12 on:
September 27, 2011, 02:36:29 pm »
I re-routed the one at the head to the filter flange
THROWN ROD
Reply #13
September 27, 2011, 04:00:29 pm
Reply #13 on:
September 27, 2011, 04:00:29 pm »
Quote from: Smokey Eddy on September 27, 2011, 02:36:29 pm
That sounds like a bad idea to me.
Measure the oil pressure at the flange. If it is within specs then the oil pump is ok.
Reply #14
September 27, 2011, 04:06:14 pm
Reply #14 on:
September 27, 2011, 04:06:14 pm »
Thanks fellers
THROWN ROD
General Information
Troubleshooting
low oil pressure
