Author Topic: low oil pressure  (Read 6926 times)
September 24, 2011, 07:04:51 pm
Smokey Eddy
  • 3468
    • McScrubbins Body Wash
low oil pressure
« on: September 24, 2011, 07:04:51 pm »
I just changed main and rod bearings <500km ago as well as lifters about 20,000km ago.
All the bearings were done when I built the engine about 40-50k ago. So the I'M shaft bearings are a little old but from what could see they looked ok.
I know the oil pump would be the next logical spot to go.
Opinions?
Cold.       Idle 2000 3000+
                 50    75     100+
 Warm      25  30/40  50
HOT       5-10    12    <20
Those numbers seem really low to me for having fresh bearings.
I'm running lubro moly fully synthetic 5w35 ( or 5w40)
It's a 1.9 aaz with a really old garret t3 from a previous 1990 1.6td.
I'm wondering if the turbo is spilling the pressure.
I changed the cold side seals and bearings but the hot side was fused shut.
Ed
Reply #1September 24, 2011, 07:38:22 pm
Wayland
  • 364
Re: low oil pressure
« Reply #1 on: September 24, 2011, 07:38:22 pm »
Did you replace the oil pump when you built the engine, or at least measure the gear backlash?
84 Grumman Olsen Kubvan
93 Dodge CTD Truck
Reply #2September 24, 2011, 07:47:38 pm
Smokey Eddy
  • 3468
« Reply #2 on: September 24, 2011, 07:47:38 pm »
I did not! :D
I'm asking if you all reckon an old turbo bleeds more oil or a worn pump causes lower pressure.
Ed
Reply #3September 24, 2011, 07:50:18 pm
Wayland
  • 364
« Reply #3 on: September 24, 2011, 07:50:18 pm »
I would strongly suspect the pump.
93 Dodge CTD Truck
Reply #4September 24, 2011, 08:08:07 pm
Smokey Eddy
  • 3468
« Reply #4 on: September 24, 2011, 08:08:07 pm »
Even if the turbo is really old? It still boosts great though...
I'll replace the pump.
Ed
Reply #5September 24, 2011, 10:10:40 pm
  • 2932
« Reply #5 on: September 24, 2011, 10:10:40 pm »
You can prime the pump with a drill and watch to see how much flows past the cam journals.
 I've had those bleed off oil pressure.
Reply #6September 24, 2011, 11:06:27 pm
Smokey Eddy
  • 3468
« Reply #6 on: September 24, 2011, 11:06:27 pm »
Hmm that's interesting although I wouldn't know what is too much?
Ed
Reply #7September 26, 2011, 10:22:36 pm
  • 2932
« Reply #7 on: September 26, 2011, 10:22:36 pm »
I hadn't done this before,.. but knew when it was flowing too much oil from journal 5.
 I did check it with plastigauge after seeing it.
Reply #8September 26, 2011, 10:26:50 pm
Smokey Eddy
  • 3468
« Reply #8 on: September 26, 2011, 10:26:50 pm »
The head isn't very old but the turbo and pump are very old. Especially in comparison. were yours pretty aged by this point?
Ed
Reply #9September 27, 2011, 09:15:24 am
rallydiesel
  • 1880
« Reply #9 on: September 27, 2011, 09:15:24 am »
Where are you reading from? Those numbers don't seem that terrible. I had an oil pressure gauge that read about 10 psi too low (VDO). Is your oil warning light blinking?
« Last Edit: September 27, 2011, 09:17:11 am by rallydiesel »
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #10September 27, 2011, 11:20:17 am
Smokey Eddy
  • 3468
« Reply #10 on: September 27, 2011, 11:20:17 am »
No blinking lights. Read from the cylinder head.
Ed
Reply #11September 27, 2011, 02:17:57 pm
BigVWman
  • 332
« Reply #11 on: September 27, 2011, 02:17:57 pm »
numbers aren't super bad. Doesn't head oil sender trigger a light at about 4.5psi and filter flange somewhere around 18-23 at 2000rpm?
Tim
83 rabbit shell 92 cabby tdi conversion, 91 cabby aba conversion, 87 cabby,  87 gti,  01nb tdi new project,00 1.8t nb, 98 ranger,92 f150 flareside(its pink) 97 cabrio and a 00 cabrio!
Reply #12September 27, 2011, 02:36:29 pm
Smokey Eddy
  • 3468
« Reply #12 on: September 27, 2011, 02:36:29 pm »
I re-routed the one at the head to the filter flange
Ed
Reply #13September 27, 2011, 04:00:29 pm
« Reply #13 on: September 27, 2011, 04:00:29 pm »
That sounds like a bad idea to me.
Measure the oil pressure at the flange. If it is within specs then the oil pump is ok.
Reply #14September 27, 2011, 04:06:14 pm
Smokey Eddy
  • 3468
« Reply #14 on: September 27, 2011, 04:06:14 pm »
Thanks fellers
Ed
