Author Topic: My Mk2 from 1.6D to 1.6TD  (Read 11183 times)
Reply #15September 02, 2011, 08:34:58 am
Re: My Mk2 from 1.6D to 1.6TD
« Reply #15 on: September 02, 2011, 08:34:58 am »
damn these guys are beatin on you like a red headed step child..
don't worry about the silicone.. i put more than that every time i've done an oil pan (many, many fords) and i've never had one come back locked up.
Fords dont care.. they will run with no oil or coolant most of the time..
VWs on the other hand, they care very much..
silicone is NOT bad for your engine if you use a light smear.. theres no reason for it to squish out of any joints..
Reply #16September 02, 2011, 10:26:53 am
osti
  • 7
« Reply #16 on: September 02, 2011, 10:26:53 am »
OK I'm explaining it once only the silicone is used to help the gaskets seal better. And YES there are new gaskets anywhere it might look like its too much but it is just the right amount it is left to dry a little and then it anything was fastened lightly so that it can dry more and after 10 hours all the things were fastened as they should be. With a torque wrench.
About the oil drain pipe the core is teflon with braided steel on the outside and something between them with inner diameter about 12 or 14mm I don't remember right now, there are no sharp turns in the drain pipe just a light curve when it connects to the oil sump.
And that's about all the whole conversion was on a very tight budget, everything including the turbo was $196. Its pretty good for a lunch money  ;)
So no worries I'm just sharring my experience if someone does not like it, well ok it does the job for me and that's all I need. I don't mind about the beatin wkdingery it's a forum after all and everybodys free to saw whatever they want.
Reply #17September 02, 2011, 10:32:51 am
« Reply #17 on: September 02, 2011, 10:32:51 am »
still dude, thats WAY too much if you are actually using gaskets.. you need a LIGHT SMEAR.. that is a FULL BEAD.
Reply #18September 02, 2011, 01:54:46 pm
damac
  • 531
« Reply #18 on: September 02, 2011, 01:54:46 pm »
I like using that copper gasket spray on all gaskets ever since I initially tried it years ago on an old 2 stroke dirtbike where the surfaces weren't perfect and previous top end gaskets would bubble.  So much easier to work with to.
1985 turbo diesel jetta
Reply #19September 02, 2011, 02:07:12 pm
« Reply #19 on: September 02, 2011, 02:07:12 pm »
fords require silicone.. helps them float when on their roof..  :-*
i use the black never hardening tar stuff permetx (sp??) sells.. wish i had the jar in front of me.. avaition something or another... works well to tack the gasket into place.. seals good.. fills any fine imperfections.. i use it on paper gaskets.. intake, old waterpump (metal so much better if you have though)type of things...
if using for a gasket helper ill live with it.. i was worried you did the ford thing and only used silicone.. newer vw does too.. just these old things.. they seem to dislike it..
gm makes a hell of a glue together engine sealent i prefer to use vs permetex by the way.. it uses one of those big silicone squirters like your doing construction work in your bathroom.. it dries faster, is less messy.. and i have never seen it spring a oil leak like i have seem with your adaptation of gasket helper.. yes ive seen silicone spring oil leaks at the oil pan with the gasket... but the gm stuff is like $15 for a quarter of the size of household silicone.. but works so good its worth the price.. ive never had to reseal one 2x..
i also use the copper spray.. i use it on metal gaskets.. aka intake manifold.. headgaskets for tdi and such.. works very nice..
Reply #20September 02, 2011, 04:03:03 pm
nathan_b
  • 361
« Reply #20 on: September 02, 2011, 04:03:03 pm »
CURIL T!
chris, you coat tdi headgaskets? any reason why? neither myke or I have had a failure using a dry gasket. In fact, just threw together a 1.8t passat, headgasket was dry as a bone, I'm talking rub your finger across any part of the head/block and it's clean/dry. that's how I always do it. Did it on my franken td as well.. as well as countless others..
Reply #21September 02, 2011, 06:46:31 pm
DieselBalz
  • 301
« Reply #21 on: September 02, 2011, 06:46:31 pm »
Thanks for sharing. You will have to forgive these guys, they mean well. They are VERY passionate about these cars, and really just want you to get the best experience out of your VW.
Reply #22September 02, 2011, 06:50:20 pm
« Reply #22 on: September 02, 2011, 06:50:20 pm »
Since when did all the a$sholes from the vortex come over to our humble forum?
Clearly from the pictures he let the silicone almost cure before he installed the pieces.. They are up on a bench, not down under the car with him. Plus he stated he let it cure before he torqued.
I see nothing wrong with using silicone on new gaskets, just a safety measure. If people didn't use a siht ton of it, do you really think they'd still be selling it?
Who cares about the aaz manifold?? I don't see it as a problem unless he is planning on 20+psi regularly and ridiculous power.. for anywhere near stock i doubt the engine even notices..
Reply #23September 02, 2011, 08:14:39 pm
« Reply #23 on: September 02, 2011, 08:14:39 pm »
ever since the subaru headgaskets i use the stuff nathan... after 3 sets.. trust me if you own subaru only buy parts from stealership.. i did not wanna chance set #3 so i used the stuff.. its just a tacky spray.. and i figured if i did 20+psi on boost a little added protection good.. :D does not hurt.. and never know may help the aluminum from corroding down the road around the water jackets.. mine had slight pitting..
yes there is some haters who posted.. LOL.. i thought he did not use gaskets at first.. why i said.. ok ill live with that when he said he used both.. :D even though ive seen people do the both on vw and they tend to leak oil after a while.. why.. no idea.. they just do..
Reply #24September 03, 2011, 09:14:05 am
« Reply #24 on: September 03, 2011, 09:14:05 am »
its more down to that jeremy ^ ^ ^
everything i pointed out, is some point of possible future failure..
the silicone, if you use ungodly amounts of it, ive seen engines grenaded from oil starvation. care to take a guess why? yup.. from silicone bits blocking the oil pump pickup..
and his copper oil line.. its got fail written all over it. i know what happens to copper tubing when subjected to the vibrations of a diesel.. IT CRACKS.
and when that copper line cracks, hes gonna lose all his oil in a HURRY. it might be fine if he catches it in time, but more than likely, it would be missed until its too late, unless his buzzer works, and he has a gauge that he pays attention to..
dude, im really not trying to flame you, promise.. just want you to be able to drive that car for a good long time.. and the way it is set up, that wont happen.
Reply #25September 03, 2011, 09:30:11 am
nathan_b
  • 361
« Reply #25 on: September 03, 2011, 09:30:11 am »
Oh chris, you reminded me that there are other cars than german ones, and that you actually subject yourself to working on them. haha.
Reply #26September 03, 2011, 11:50:20 am
« Reply #26 on: September 03, 2011, 11:50:20 am »
sadly the vws i work on do not break often enough to keep me with $ in pocket..  ;D  fords do...  :P
