Author Topic: ALH ECU difference  (Read 3504 times)
August 19, 2011, 01:32:04 pm
Big Daddy Roth
  • 298
ALH ECU difference
« on: August 19, 2011, 01:32:04 pm »
Can I replace a 038 906 012 FD ECU with a 038 906 012 GN ecu? I suspect the difference is the immobilizer. Can I get around it with vag-com?
1993 TD B3 Sedan
1992 G60 Syncro B3 Sedan
Reply #1August 19, 2011, 02:22:56 pm
BigVWman
  • 332
Re: ALH ECU difference
« Reply #1 on: August 19, 2011, 02:22:56 pm »
I'm not personally familair with either code, but if either has an immo then no you cannot! The immo is specific to the trio ecu, ignition key, and cluster! Also vag com isn't much help with immo you'll need an ecu programming person to take the immo out or recode it. IIRc the cluster actually has the immo brain but the programmer can tell the ecu not to check for it.
Tim
83 rabbit shell 92 cabby tdi conversion, 91 cabby aba conversion, 87 cabby,  87 gti,  01nb tdi new project,00 1.8t nb, 98 ranger,92 f150 flareside(its pink) 97 cabrio and a 00 cabrio!
